Does a rigid box of gas cool over cosmological timescales?
In summary, according to standard cosmology theory, the physical momentum of both massive and massless particles decays according to ##p \propto \frac{1}{a(t)}##, where ##a(t)## is the scale factor as a function of cosmological time. However, this assumption only holds for particles that are moving freely, and if they are confined inside a rigid box, they are not moving freely. Therefore, this does not imply that a gas inside a rigid box cools over cosmological timescales, in addition to the effect of external blackbody radiation from the box itself.
jcap
170
According to standard cosmology theory the physical momentum [itex]p[/itex] of both massive and massless particles decay like:
$$p \propto \frac{1}{a(t)}$$
where [itex]a(t)[/itex] is the scale factor as function of cosmological time [itex]t[/itex] (for a derivation see page 12 in the following lecture notes: http://www.damtp.cam.ac.uk/user/db275/Cosmology/Lectures.pdf).
Does this imply that a gas inside a rigid box cools over cosmological timescales (in addition to the effect of external blackbody radiation from the box itself)?
As I understand it one can model a particle with rest mass as a rigid box with massless particles confined inside it (cf. proton mass mostly due to confined gluons). If the momentum of the massless particles decay then that implies that the system itself loses energy as the Universe expands. I presume that the massless particles will no longer redshift once their wavengths are comparable to the size of the box. Therefore the energy of the system as a whole will tend towards a constant value with increasing cosmological time. Does rest mass decay with cosmological time? I presume not as we would have seen the observational consequences of this effect.
Space news on Phys.org
jcap said:
According to standard cosmology theory the physical momentum ##p## of both massive and massless particles decay
This assumes that the particles are moving freely. If they are confined inside a rigid box, they are not moving freely.
No. See above.
Related to Does a rigid box of gas cool over cosmological timescales?
1. What is a rigid box of gas?
A rigid box of gas refers to a theoretical model where a certain amount of gas is contained in a perfectly sealed and unchanging volume. This means that the volume, pressure, and temperature of the gas remain constant over time.
2. What is meant by "cooling" over cosmological timescales?
Cooling in this context refers to a decrease in the temperature of the gas within the rigid box. Cosmological timescales refer to the vast timescales involved in the evolution of the universe, spanning billions of years.
3. How does a rigid box of gas cool over cosmological timescales?
As the universe expands, the gas within the rigid box also expands. This expansion results in a decrease in temperature due to the decrease in density of the gas. Additionally, as the universe ages, the gas particles also lose energy through radiation, leading to further cooling.
4. Is the cooling of a rigid box of gas a constant process?
No, the cooling of a rigid box of gas is not a constant process. It depends on the initial conditions of the gas, such as its density, composition, and energy. As the universe expands and the gas particles lose energy, the cooling process may slow down or even stop entirely if the gas particles reach a state of thermal equilibrium.
5. Why is the cooling of a rigid box of gas important in understanding the evolution of the universe?
The cooling of a rigid box of gas is important because it is one of the key processes that contribute to the overall evolution of the universe. It helps us understand how the universe has changed over time and how the different components within it, such as gas and galaxies, have interacted and evolved.
  • Other Physics Topics
9K
  • Cosmology
  • Science and Math Textbooks
