High School Does air resistance have a max value?
Air resistance does not have a theoretical maximum value like static friction, but it does reach a limit in free fall known as terminal velocity. This occurs when the gravitational force acting on the object is balanced by the drag force, or air resistance. The drag force is influenced by factors such as the object's shape and orientation, which determine the drag coefficient. In practical terms, the maximum air resistance experienced is equal to the object's weight at terminal velocity. Understanding these dynamics clarifies how objects behave when falling through the atmosphere.
r4g3r4hk
I know that friction on a surface has a maximum value. When an object is pushed with a force greater than the maximum friction value, the object will move.
But when a free-falling object falls from a height, does air resistance have a maximum value as well?
That's an odd way to view it. Static friction is a function of the normal force. There is no theoretical limit, only practical/materials limits.
By constraining the scenario to [atmospheric, I assume] free fall, you are defining the drag limit to be equal to the weight of the object.
Likes Lnewqban and r4g3r4hk
Thanks for the replies! I believe I understand now.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 20 ·
  • · Replies 19 ·
  • · Replies 27 ·
