Does an electric charge curve spacetime ?
In summary, the conversation is discussing the possibility of developing a theory similar to General Relativity (GR) using the postulates of spacetime curvature caused by electric charges instead of mass. The conversation also mentions the Einstein Equivalence Principle (EEP) and the difficulty of unifying gravity and electromagnetism. It is suggested that a spin 2 field in GR only allows for attraction, not repulsion, and that this would require negative energy. However, the conversation concludes that the premise of GR cannot be applied to electromagnetism as it is easy to distinguish between gravity and acceleration in the presence of electric fields.
  • #71
I am a statistician, I wanted to know whether light is a wave or a particle ? And what is light in string theory ?
  • #72
Short answers. Yes. and The Same.
Longer answer, since early in the twentieth century light has been viewed as having both particle and wave properties. Which property you see depends on what experiment you do; if your experiment concerns, say, frequency or interference you will detect waves, and if you do an experiment based on momentum, you will detect particles. This idea actually came out of experiments, not theory, and it was only later includied in the growing theory of quantum mechanics.
String theory builds particles at the wave level out of string vibrations, so it basically supports this wave/particle duality.
  • #73
pervect said:
This means that _uncharged_ particles, following a geodesic, will not follow the same path near a charged black hole as they will near an uncharged one with the same mass.
This should, in theory, be testable using neutral particles in a large electric field. If it is true for black holes it should be true everywhere.
Here's another thought.
The curvatures (positive and negative) do not need to be thought of as being in the same direction as the gravitational curvature. They can be looked at as being orthogonal to it.
They can also be looked as a twisting of space/time, rather than a curvature.
juju
  • #74
I have a question:-from the little bit that I know,any physical field except the gravitational is a part of T_{mu,nu} and causes curvature.Has any experiment
ever been done which shows that the electromagnetic field causes space-time
curvature?Are static fields from charges also included in T_{mu,nu}?
  • #75
Thanks for the reply. Sorry I would love fire in some more so please ...
In the duality priniciple , how does it explain an energy dissipation ?
Another question is as how does Light travel continously for an infinitely long distance (say sun to Earth )?
Atmosphere starts at some good distance above Earth's surface then in absence of vacuum , shouldn't the light get decayed ?
If you answer that its too powerful so it reaches us then shouldn't be too bright and hot above Earth atmosphere.
  • #76
Welcome to Physics Forums raodhananjay!
A suggestion if I may: your questions are good ones, but are not related to relativity, or to whether (and to what extent) electric charges curve spacetime - perhaps you could start a thread with these questions, in Quantum Mechanics?
It doesn't, directly; dissipation involves absorption (and, maybe, re-emission).
As far as we can tell, there is no limit to how far light can travel. The furthest we've seen - and indeed, the further we can ever see - is the surface of last scattering, approx 13 billion light-years.
Some of the photons incident on the top of the Earth's atmosphere are indeed absorbed or scattered; astronomers measuring the apparent magnitude of a star include a correction - called 'air mass' - in their data reductions.
  • #77
T_{mu,nu} = [tex]T_{\mu \nu} [/tex] is the stress energy tensor, and as was previously mentioned, yes, the static electric field generates terms in the stress-energy tensor. As was also mentioned, the contribution is a trace-free one. This means that Baez's ball of perfectly electrical neutral coffee grounds
http://math.ucr.edu/home/baez/gr/outline2.html
don't change in volume (gravitate together) because of the electric field, as the trace of the stress-energy tensor determines R00. However, the presence of the electric field does curve space-time.
  • #78
pervect,thanks for your answer.I repeat the second part of my question:-has any experiment ever been done which shows that the electromagnetic field causes space-time curvature?
  • #79
If you don't mind, I'd like to ask a slightly different question ... with our current experimental capabilities, *could* we do an experiment which would show that an 'electromagnetic field causes space-time curvature'? In principle, what would an experiment to test the idea look like?
  • #80
Your question 'suggests' to me that with our present capabilities,we can't produce such high intensity electromagnetic fields---enough to cause any significant spacetime curvature.Can you give an order of magnitude calculation to give us an idea?An experiment to test the idea could look like this---if light bends in region of such a high intensity electromag. field(perhaps we could concentrate on just the magnetic field and try producing extraordinarily strong magnets)then we would know that the curvature has been produced.But I am sure there must be better ways around.
  • #81
There are some relevant experimental tests, but they may not be very satisfying. For instance, Eotvos type tests comparing aluminum and gold.
Columb energy, (i.e. the energy in the electrostatic field), which is proportional to [nuclear charge]^2, amounts in a gold nucleus to .4 percent of the mass, but only .1 percent of the mass in an aluminum nucleus. Very sensitive experiments have been done to detect any differences in gravitational forces on aluminium and gold, (testing the principle of equivalence), but none have been found.
  • #82
Let's think about this from the PoV of what the most intense EM fields and greatest spacetime curvature is, in the present universe, and later we'll examine whether any of these are amenable to tests - even in principle - of well-formed hypotheses. OK?
First, the most intense magnetic fields, in the present universe, are likely to be http://solomon.as.utexas.edu/~duncan/magnetar.html , whose fields are likely to be as many OOM stronger than the strongest we can generate here on Earth is greater than the Earth's own field.
Next, the most energetic gammas may well have a comparable 'curvature effect' to objects whose gravity we can measure. For example, we have 'seen' TeV gammas from the Crab pulsar (or nebula), and expect that GRBs emit PeV or higher gammas (such energetic gammas probably cannot propogate clear across the universe, but as we've 'seen' a couple of nearby AGN in TeV, perhaps a nearby GRB might be 'visible' in PeV gammas). Homework question: if a TeV gamma were converted (magically) into a lump of baryons (yes, it would be magic!), what would the mass of that lump be?
Next (2), it may be that a 'long duration' GRB results in the formation of black hole whose mass is several times that of the Sun. If the progenator star had a magnetic field, it may be that, in the last few microseconds before the BH formed, that field reached an intensity which makes a magnetar's field look like a fridge magnet. Too, the spacetime curvature would be far more extreme than that around the Sun (which has provided the most sensitive tests of some aspects of GR to date).
Finally, as the two neutron stars in a binary merge/collide (they lose energy as gravitational waves; without some external event, a collision is certain), many kinds of extreme environments will likely be created.
Closer to home, you might like to read the reports of the Fundamental Physics Working Group (it's in the middle of the page), from the recent ESA Cosmic Visions workshop. Do you feel that any of the proposed (local) experiments would test a hypothesis related to spacetime curvature resulting from EM?
  • #83
You lost me with GRB and AGN.
But surely, one could calculate the deviation of a beam of light due to an earth-built electric or magnetic field, even if the deviation is in order of femtometers or less.
I finally received my first book on tensors. GR is next. Hopefully, I'll see what the difficulty resides.
  • #84
Gamma ray burst, active galaxy nuclei (http://www.ulo.ucl.ac.uk/~diploma/year_one/heasarc.gsfc.nasa.gov/docs/objects/agn/agntext.html ).
You mean, for example, moving a strong permanent magnet close to and away from a LIGO arm?
  • #85
Thanks NEREID . Sorry , you are right , I guess should be asking related questions. Let's start now, I had been inspired by one of the posts , hence I started my queries here. Otherwise although the header " electric .. " of this thread made me curious , I am kind of lost here. Ok Is Somebody ready to do small revision or introduction of things you do here. PLEASE somebody do that for me.
  • #86
Nereid said:
Gamma ray burst, active galaxy nuclei (http://www.ulo.ucl.ac.uk/~diploma/year_one/heasarc.gsfc.nasa.gov/docs/objects/agn/agntext.html ).You mean, for example, moving a strong permanent magnet close to and away from a LIGO arm?
Exactly, but perhaps an electrically-generated magnet instead (MRI systems etc.). I would think that superconducting AC would generate the strongest human-made B-fields possible.
  • #87
Re-reading some of the posts near the start of this thread gave me the idea that perhaps we should be a little more precise about what any experiment is trying to test.
Gonzolo started this thread with a question about whether electric charge could 'curve spacetime', and in the last few posts we've been discussing whether a magnetic field can 'deflect' a beam of light. Would someone please be kind enough to explain why a non-null result in the latter would lead one to conclude 'yes, it can' for the former?
  • #88
I assume that in free space, all that can deflect a beam of light is space-time curvature. So whether the electric charge is moving (B-field) or not (E-field) can be seen as a detail (although certainly not for calculations). The question is for EM in general.
  • #89
Hi,
If EM fields curve space/time then time dilation effects should be seen. These would manifest in the changing of particle decay rates.
juju
  • #90
I have a similar problem with the question. Curvature of space-time necessarily means that the frames of reference of all inertial observers would we affected. Since only charged masses would be affected by the presence of another electric charge, electrically neutral masses would measure time and space without being affected. How can this be a curvature of space-time?
Besides, Maxwell's equations state that the speed of propagation of an electromagnetic wave depends only on the values for [itex]\epsilon_0[/itex] and [itex]\mu_0[/itex] (the permittivity and permeability constants for space). These are experimentally derived and and neither of these constants depend on the magnitude of the respective electric or magnetic fields.
Calculex
  • #91
As light is an EMW I think (feel) the magnetic fields (extremely strong of course) may be able to deflect the light.
  • #92
Uncharged masses *are*affected by the presence of electric charge (according to GR). This is why the Reissner-Norsdstrom metric for a charged black hole is different from the Schwarzschild metric for an uncharged black hole. Note the additional Q^2/r^2 terms in the Reissner-Nordstrom metric.
http://reissner-nordstrom-black-hole.wikiverse.org/
http://en.wikipedia.org/wiki/Schwarzschild_metric
This happens because electromagnetic fields are a form of energy, and thus contribute to the gravitatioanl field.
In GR, electromagnetic fields contribute to the stress energy tensor (the RHS of Einstein's field equations), which implies they contribute to curvature (the LHS of Einstein's field equations)
http://math.ucr.edu/home/baez/physics/Relativity/GR/energy_gr.html
Now, the Einstein field equations are
Gmu,nu = 8pi Tmu,nu
Here Gmu,nu is the Einstein curvature tensor, which encodes information about the curvature of spacetime, and Tmu,nu is the so-called stress-energy tensor, which we will meet again below. Tmu,nu represents the energy due to matter and electromagnetic fields, but includes NO contribution from "gravitational energy".
  • #93
Hi all,
There is a problem when dealing with the EM energy of the field created by a charged particle,
If it is only potential energy activated by another charge, then there would be no effect on neutral particles and probably no curvature in the GR sense,
However, if it results from a scaler energy field, then even if the force vectors cancel from the fields of two or more charges, the scaler energy fields from all the particles still exist and would add, producing more curvature than would be calculated just from a resultant EM vector field.
juju
  • #94
pervect said:
Uncharged masses *are*affected by the presence of electric charge (according to GR). ...
This happens because electromagnetic fields are a form of energy, and thus contribute to the gravitational field.
A charge in an electric field has energy which is the product of its charge and the electric potential of the field where the charge is located. The units of an electric field are Energy/charge (eg. volts or joules/coulomb). So is it correct to say that an electric field represents stored energy in the absence of another mass having a charge? I should think that there would be no energy represented by the field itself.
AM
  • #95
Yes, the field itself has a local energy density (at least in SR where such things are well-defined). Think of radiation for example.
Anyways, GR states that geometry couples to the stress-energy tensor, not "energy density," whatever that may be. Electromagnetic fields have a well-defined stress-energy tensor, so they do generate gravitational fields. They are usually very small, but were significant in the early universe. I think that the CMB experiments have verified this.
As for measuring the gravity of EM fields directly, I think that's hopeless for now. For order of magnitude purposes, it is ok to think of the mass as being due to an energy density. Then the effective mass is ~E/c^2. I don't think we can measure gravitational effects for things less than a few kilograms (I may be wrong!), which implies an energy of ~10^17 Joules. This must also be localized to within less than 10 cm or so. So the required energy density for a "tabletop" experiment is about 10^20 J/m^3. The electric field strength required is about 10^15 V/m. The requisite magnetic field strength is about 10^7 Tesla. Very large fields can be achieved for with special lasers, but they are so fleeting that I doubt any gravitational effect could be measured.
  • #96
The field itself has energy, even if there is no charge in it. Consider two electric charges that repel each other. Bring them closer together. It requires work to do so. The energy to do this work is not lost, but it is stored as potential energy. Where is this energy stored? In the electric field.
The expression for the field energy of an electromagnetic field is given at
http://scienceworld.wolfram.com/physics/ElectromagneticField.html
Yes, this is true.
For general information, the energy density (energy per unit volume) is one of the components of the stress-energy tensor.
If you represent a volume of space by a 4-vector orthogonal to the volume, the stress-energy tensor can be thought of as the density of momentum-energy per unit volume. Multiplying the stress energy tensor Tij by the vector Vi representing a volume element yields the energy momentum 4-vector contained in that volume.
  • #97
AFAIK, tests (and measurements?) of gravity are now into the 100 micron, 1 mg range (e.g. this interesting summary)
10^7 Tesla = 10^11 Gauss, which is far, far above what's achieved here on Earth (compression via explosives); however, it's weak for a neutron star, and mere noise near a http://solomon.as.utexas.edu/~duncan/magnetar.html .
Aye, that's the real challenge - how to build an experiment to measure a gravitational effect that's both weak and fleeting? Perhaps repetition and nulling (differencing) are the answers?
  • #98
You have merely pointed out that a charged particle in an electric field has potential energy. My point was that a static electric field which surrounds a charged mass contains no energy UNLESS you bring another charge into it.
When there is a charge in an electric field, that charge has electric potential and one can think of the energy being stored in the field, with its units being that of kQq/r. When there is no charge q in the electric field created by charge Q, I don't see how the field can have any energy.
One way to ask the question is this: when a charge is created, does energy go into creating its electric field? (e.g neutron decaying to proton, electron and antineutrino?). I don't know the answer to that. I am just wondering.
AM
  • #99
It's interesting that 'charge' is created in pairs, in this example, and in all cases (?).
A somewhat similar situation is the 'destruction' of 'mass', e.g. annihilation (e- + e+ -> 2 photons, for example) ... from the GR perspective there is no loss of 'that which creates spacetime curvature', merely conversion of one form (two particles) to another (two different particles, moving at c).
So perhaps a different way of asking this is whether the 'QM' conservation laws (e.g. charge, those 'built in' to the weak and strong forces) are 'built in' to GR?
  • #100
This gets into some interesting but advanced territory. It's fairly well known that the field energy of a charged point particle (usually, this is talked about as the self-energy of the electron) is infinite.
Google finds the archived physicsforum post
https://www.physicsforums.com/archive/t-29348_Electrostatic_Field_Energy_of_Electron.html
as a previous discussion about this point.
This issue requires quantum mechanics to resolve - unfortunately, GR isn't a quantum theory.
  • #101
pervect said:
This gets into some interesting but advanced territory. It's fairly well known that the field energy of a charged point particle (usually, this is talked about as the self-energy of the electron) is infinite..
This is only true if it is assumed that the field structure close to the convergence point of the field (the point particle) is the same as the field structure further away (the normal field structure.)
juju
  • #103
Weyl's conformal tensor?
  • #104
It's the usual Weyl tensor, the traceless part of the Riemann. Someone explained to me once why it's sometimes called a "conformal tensor", but alas I don't recall the details.
http://mathworld.wolfram.com/RiemannTensor.html
reviews the breakdown of the Riemann into the Ricci and the Weyl tensors.
Unfortunately this is about as far as I've gotten with the paper so far, I don't understand the main point of it yet.
[edit]
The key term I'm missing the meaning of is
"the same support as the matter", it probably has something to do with homology which I don't know much about.
[end edit]
  • #105
If you're asking what support means, that's the portion of a function's domain where it is nonzero. The sentence is saying that whatever it is discussing is nonzero only where there is matter.
The Weyl tensor is also called the conformal tensor because it is invariant under conformal transformations (multiplying the metric by a scalar function).
