Does antineutrino capture preferentially form neutrons?
In summary, the process of antineutrino capture can change quark flavor, with the most preferred reaction being p+ν=n+e+. However, at high energies, the conversion of proton into n is still preferred over conversion into any specified flavor of Λ. This is due to the different CKM matrix elements involved.
snorkack
2,242
489
Besides the energetic preference (lower threshold, and more phase space above)?
Antineutrino capture is a weak process, so it can and does change quark flavour.
p+ν=n+e+
is actually
uud+ν=udd+e+
that is
u+ν=d+e+
But given enough energy (like cosmic ray neutrinos), do antineutrinos also get captured:
p+ν=Λ+e+?
Because this is just
udu+ν=uds+e+
that is
u+ν=s+e+
As you see, even though baryon charges match, a process
p+ν=Ξ+e+
would be obstructed, because Ξ has 2 s quarks. But process
p+ν=Λb+e+
should be just
u+ν=b+e+
Obviously these processes are impossible below energy threshold, and above they have a phase space factor. But at high energies, does proton conversion into n vs conversion into any specified flavour of Λ approach ratio of unity, or will any difference remain?
You would have different CKM matrix elements in there. And ##|V_{ud}| > |V_{us}| > |V_{ub}|##. So I would say yes, ##p+\bar{\nu}\to n+e^+## is preferred over ##p+\bar{\nu}\to \Lambda+e^+## even setting aside phase space constraints.
Edit: changed ##\nu\to\bar{\nu}##, see below
Likes malawi_glenn
But it should be ##p+\bar{\nu} \rightarrow n+ e^+##.
  • Care
Likes Dr.AbeNikIanEdL and malawi_glenn
Indeed, I just copied the reactions as noted in the OP (all ##\nu## there should also be ##\bar{\nu}## but the text correctly says antineutrino).
Likes vanhees71
