Does anyone know how to solve i try to self learn?
  • Thread starter Thread starter sammy852
    Self
The discussion focuses on solving physics problems using fundamental equations of motion and forces. Participants are tasked with finding mass (m) using ΣF = ma, calculating acceleration (a) with friction coefficients, and determining the validity of static friction equations. Specific problems involve manipulating equations to isolate variables and apply known values to derive solutions. The conversation emphasizes understanding algebraic manipulation to solve for unknowns in physics contexts.
sammy852
The equations used are:
1)ΣF=ma
2)fk = μkN
3)fs ≤ μsN
4)Fs = - kx
Here are the questions:
1. If ΣF is 10N and a=1 m/s^2, find m using the first equation
2. Given ΣF = fk, m=250 kg, μk=0.2, and N = 10m, find a.
3. ΣF=T-10m, but a=0 m/s^2. Use the first equation to find m in terms of T.
4. Given the following values, determine if the third equation is valid. ΣF =fs, m=90kg, and a=2 m/s^2. Also, μs=0.1 and N=5N.
5. Use the 4th equation to solve for F, if k=900 N/m and x=0.15m
6. Use this equation ( vf=v0+at) and (ΣF=ma) find ΣF when m=12kg, vo= 15m/s,vf=5/ms and x=0.15m
Well let's start with the first problem,
You know:
ΣF = 10N
a = 1 m/s^2
m = ?
And better yet, you know you have to use ΣF = m*a
Are you familiar with how to solve for a variable in an algebraic equation?
For example, can you solve for x in this equation?
6x = 52
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
