I Does combusted gas travel faster in a vacuum tube?
Combusted gas is expected to travel faster in a vacuum tube due to reduced particulate collisions compared to a regular tube. However, the pressure differential created by the vacuum may pose challenges when puncturing the tube. When combusted gas is used to propel a projectile in a vacuum, it is theorized that the projectile would also travel faster due to fewer molecules obstructing its path. The discussion raises questions about the dynamics of pressure and resistance in both scenarios. Ultimately, the effects of vacuum dynamics on gas behavior and projectile acceleration remain complex and warrant further exploration.
Limebat
TL;DR Summary
Hey all,
So if a gas is combusted, would it travel faster through a vacuum tube or a regular ole' tube? I would assume the vacuum tube, as there are less particulates collisions in the way of the fast-moving gas molecules. Yet this also implies pressure on the outside of the thin barrier _ 2, indicating a large pressure resistance would be met when puncturing the last stretch of the tube. I am unsure because I haven't taken any gas dynamics / thermo classes yet. It would help a good bit if anyone can answer!
- Bonus question:
If an object is put at the beginning of the vacuum tube, then the gas is combusted, would the projectile travel faster? I would assume the same idea would happen - less molecules in the way / other reasons not to. However, the combusted gas is assumed to fill only the area behind the projectile, not in front. Meaning vacuum dynamics would probably only apply to the projectile and its forces propelling it. So this probably turns into a classical physics problem, where:
Is an accelerating projectile faster in vacuum rather than not in a vacuum?
Limebat said:
Summary:: Does combusted gas travel faster in a vacuum tube?
Hey all,
- Bonus question:
So we have two identical guns. One has a thin piece of plastic over the end so that the barrel is evacuated. The other has the same thin piece of plastic over the end, but with a pinhole leak so that the barrel is filled with air.
We place identical shells in each gun's firing chamber. The shells have no bullet. Just propellant.
You want to know what, exactly?
Which piece of plastic breaks first if both guns are fired simultaneously?
Ah, I would assume the one with the plastic end (no hole) would break first; until the combusted gas molecules hit the plastic walls, air resistance becomes the key player in the flame front velocities. Assuming the caps are infinitesimally small, meaning any applied chamber force could break either, the plastic end (no hole) would break first.
*Note; this is just a guess of mine. I'm not entirely sure if this is correct.
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
