Does Convergence at Zero Imply Global Convergence for Power Series?
  • Thread starter Thread starter Hummingbird25
    Convergence Series
Hummingbird25
Dear all
If a series e.g. a power series results in x convergering towards zero, can then one conclude that this series converge for all number if let's x belongs to R?
Sincerely Yours
Hummingbird25
what do you mean by R? the ratio between terms?
I believe Hummingbird was referring to the set of real numbers (often denoted by R). The answer to the question (if I read it correctly, I had to read it a few times) is no also, look up "radius of convergence".
Hummingbird25 said:
Dear all
Sincerely Yours
Hummingbird25
This makes no sense at all. "A power series results in x converging towards zero"? First of all, x does not "converge" toward anything. It is a variable. Second, I don't know what you mean by saying "a power series results" in that.
If I really had to guess, I would guess you are asking about the "ratio test". If, for any series of positive numbers
\Sum_{n=0}^\infnty a_n the sequence \frac{a_{n+1}}{a_n} converges to any number less than 1, then the series converges.
From that it follows that if, for the power series \Sum_{n=0}^\infty a_nx^n[/itex] and some specific x, the ratio \left|\frac{a_{n+1}}{a_n}\right|\left|x\right| is less than 1 then the series converges for that x. In particular, if \left|\frac{a_{n+1}}{a_n}\right| converges to 0 then the above will converge to 0 &lt;1 for <b>all</b> x and so the power series converges for all x.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
