Does Dark matter get trapped in black holes and increase their mass?
In summary: It's a bit like fairies at the bottom of the garden, for me. Until there's some serious, unequivocal evidence I'm not very interested in 'photoshopped' images of little girls...
jms4
37
Dark matter passes through everything, but is only influenced by gravity, so in the case of a neutron star, since dark matter doesn't interfere with ordinary matter, it can just pass through it, but neutrinos might be stopped by it's density, as neutrinos can just pass through stars almost as if they don't exist. The problem is black holes,
1. Does dark matter get trapped in black holes and increase it's mass
2. Does dark matter pass through it as if it doesn't even exist? it gets accelerated into the black hole's event horizon faster than the speed of light by it's gravity, then, passes through it and comes out of the event horizon on the other side?, but astrophysicists say nothing can come out of a event horizon.
Astronomy news on Phys.org
Yes. NOTHING can escape a BH once it goes past the event horizon
Nothing travels faster than c, so you have a misunderstanding here.
Likes stefan r
Yes, the hypothetical particles must obey general relativity too.
Also, dark matter may well be captured by neutron stars. Very weakly interacting does not mean no interaction, and neutron stars are exceedingly dense. If dark matter can occasionally interact weakly with a neutron star, it can be gravitationally captured. See the following for consequences of various assumptions:
https://arxiv.org/abs/1201.2400
PAllen said:
Also, dark matter may well be captured by neutron stars. Very weakly interesting does not mean no interaction, and neutron stars are exceedingly dense. If dark matter can occasionally interact weakly with a neutron star, it can be gravitationally captured. See the following for consequences of various assumptions:
Personally, I find DM to be more than very weakly interesting. :oldlaugh:
  • Haha
Likes sophiecentaur, WWGD and Ibix
As others have noted, this is not how it works. Essentially a black hole is a region of spacetime that is "shaped" (not quite the right word, but it'll do) so that there are no paths leading back across the event horizon. Thus it doesn't matter if incoming particles interact with other matter or not (edit: and GR doesn't have matter anywhere inside the hole anyway) - once they are in there is no route out.
Likes Dragrath and jms4
Fixed
phinds said:
Yes. NOTHING can escape a BH once it goes past the event horizonNothing travels faster than c, so you have a misunderstanding here.
Right, I was thinking about the concept of digging a hole through a uniform sphere planet's axis with no atmosphere and doping a ball through it, it comes out the other side the same force it enters in with, that couldn't work with black holes though as it breaks the light limit.
Thanks
jms4 said:
Right, I was thinking about the digging a hole through a uniform sphere planet's axis and doping a ball through it, it comes out the other side the same force it enters in with, that couldn't work with black holes though as it breaks the light limit.
A black hole is vacuum, so I don't think you could dig through one!
This was a thought experiment I've read in a book once, nothing to do with black holes here.
That does indeed work for massive objects made of normal matter, and we'd expect dark matter to pass through without being slowed. You are correct that it doesn't work with black holes, but this is nothing to do with the speed of light limit. It's to do with the geometry of spacetime being such that you simply cannot describe a particle leaving the event horizon.
Likes jms4
It's a bit like fairies at the bottom of the garden, for me. Until there's some serious, unequivocal evidence I'm not very interested in 'photoshopped' images of little girls in fairy costumes.
Gravitational lensing from matter invisible at all EM frequencies doesn’t count as evidence for you?
Note, for comparison, no one has or ever will directly measure a quark (unless QCD is fundamentally wrong). We accept accumulated indirect evidence for quarks.
Something is there and it does quack like a duck. For the time being, we call it a duck but it's all pretty elusive. I think the 'measurable rules' that are followed in elementary particle physics are very consistent and give a bit more (?) firm indirect evidence for Quarks.
Related to Does Dark matter get trapped in black holes and increase their mass?
1. What is dark matter?
Dark matter is a type of matter that does not interact with light or other forms of electromagnetic radiation. It is thought to make up about 85% of the total matter in the universe and is responsible for the observed gravitational effects on galaxies and other large-scale structures.
2. How does dark matter get trapped in black holes?
Dark matter does not get trapped in black holes in the same way that regular matter does. Black holes have a strong gravitational pull that can attract and capture regular matter, but dark matter does not interact with this gravitational force in the same way. However, it is possible for some dark matter particles to get close enough to a black hole to be pulled into its event horizon.
3. Can dark matter increase the mass of a black hole?
Yes, dark matter can increase the mass of a black hole. As dark matter particles get pulled into a black hole's event horizon, they contribute to the overall mass of the black hole. This is one way in which black holes can grow in size over time.
4. How much of a black hole's mass is made up of dark matter?
It is difficult to determine exactly how much of a black hole's mass is made up of dark matter. This is because dark matter is not directly observable and its distribution around black holes is not well understood. Some studies have suggested that a significant portion of a black hole's mass could be made up of dark matter, while others have found that dark matter makes up a smaller fraction of a black hole's mass.
5. How does the presence of dark matter affect black holes?
The presence of dark matter can have a significant impact on the formation and growth of black holes. As dark matter particles are pulled into a black hole's event horizon, they can contribute to its mass and potentially make it more massive. Additionally, the distribution of dark matter around a black hole can affect its gravitational pull on surrounding matter, potentially influencing the growth and behavior of the black hole.
  • Astronomy and Astrophysics
