I Does gravitational energy travel like electrical energy?
Electrons flowing through a resistor dissipate electrical energy, which is transported from the battery via the Poynting vector's curved field lines. The discussion raises the question of whether a similar concept applies to gravitational energy, using the example of sand falling through the air. It suggests that gravitational energy may not travel in the same way as electrical energy, as localizing energy in a gravitational field is complex and often elusive. While there are instances, like gravitational waves and the Penrose process, where energy transfer through gravitational fields can be argued, a definitive answer about gravitational energy flow remains elusive. Overall, the dynamics of gravitational energy differ significantly from those of electrical energy.
Orthoceras
TL;DR Summary
Electrons flowing through a resistor are dissipating electrical energy. The electrical energy is transported from the battery to the electrons along the curved field lines of the Poynting vector. It seems like a meaningful idea that electrical energy necessarily travels from the source to the dissipation site.
My question is, does this idea somehow apply to gravitational energy as well? For example, consider a steady stream of sand falling through the air, from a funnel to the ground. Is the gravitational energy actually transported from the source (i.e., the funnel or the ground) to the dissipation site, where sand particles experience air resistance? If not, does gravitational energy not travel? Is gravitational energy more elusive than electrical energy?
There are a lot of similarities between electromagnetism and gravity, but there are a lot of differences too. When thinking about flowing "charge" you have to remember that there are no opposite charges, so there's nothing quite like a current in a wire with a net zero charge. Also, like charges attract so the dynamics are rather different. Furthermore, localising energy in a gravitational field is notoriously difficult in all but the very simplest of circumstances, so it can prove very difficult to ask (rigorously) if energy has flowed anywhere.
So, as far as I understand it the "answer" to your query in general is that we don't really have a way to answer.
However, there are cases where you can argue that energy has transferred through the gravitational field. Gravitational waves are one such - Feynman pointed out that a pair of beads on a straight wire should move together and apart under the influence of a passing gravitational wave, and friction with the wire would generate heat, presumably sapping energy from the wave. And you can use the Penrose process to sap angular momentum from a black hole, again presumably passing energy through the field since there's nothing to touch.
Likes malawi_glenn
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
