Undergrad Does high humidity air transfer sound better than dry air?
High humidity can affect sound transmission, with humid air being less dense than dry air, potentially altering sound quality. Wet road conditions increase tire noise, indicating that moisture can enhance sound propagation in certain environments. Hot air's ability to hold more moisture compared to cold air may also influence how sound travels. Additionally, temperature stratification can create a waveguide effect, allowing sound to travel further than the typical inverse square law would suggest. Overall, humidity and temperature play significant roles in sound transmission dynamics.
gary350
TL;DR
Sometimes highway traffic 1/4 mile away sounds like its in our yard then other times traffic is hardly noticeable.?
2 weeks of no rain traffic is hardly noticeable. Now 5 days of none stop rain traffic sounds like its in the back yard.
Road traffic makes more tire noise when the road is wet.
Humid air is less dense than dry air at the same temperature and pressure.
Hot air can dissolve more moisture than cold air.
A horizontal stratification of temperature can duct sound in a waveguide, rather than inverse square law.
Likes Vanadium 50, Lnewqban, vanhees71 and 1 other person
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 42 ·
11K
  • · Replies 16 ·
