Does repeating a data transmission constitute spreading?
  • Thread starter Thread starter Tybalt
    Data Transmission
Repeating a data transmission can be seen as a form of spreading, as it utilizes more bandwidth than necessary for the signal. This is illustrated by TCP-IP's retransmission of packets upon receiving a NACK, which could be classified as a spreading scheme. In OFDM, interleaving data across subcarriers increases spectrum occupancy without changing total bandwidth, leading some to refer to this as spreading. Frequency-domain interleaving introduces repetition in the time domain, where the output of the IFFT can repeat based on the number of zeros inserted between data symbols. Understanding the distinction between spread spectrum techniques and data duplication in diversity schemes is crucial for clarity in this discussion.
Tybalt
TL;DR Summary
This is a question about defining spread spectrum. It seems that spreading should involve more than just repeating data symbols.
Generally, spread spectrum is defined as using more spectrum (or bandwidth) than is needed to transmit a signal. But according to this definition, even TCP-IP would be a spreading scheme because it retransmits packets upon receiving a NACK. In OFDM, if you interleave data across the subcarriers instead of using a contiguous block of subcarriers, you increase the spectrum occupancy, but the total bandwidth (= number of subcarriers x subcarrier bandwidth) is the same. Some people call this spreading. Interleaving involves inserting zeros between data symbols that are operated upon by the IFFT, so this frequency-domain interleaving causes repetition in the time domain, i.e., the output of the IFFT repeats Z times, where Z is the number of zeros you insert between the data symbols.
Thanks. This is helpful.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
