- #106
- 8,938
- 2,946
DrChinese said:This is Bell's condition that the setting at A does not affect the outcome at B, and vice versa. You could call that the Locality condition. The other one is the counterfactual condition, or Realism. Obviously, the standard and accepted interpretation of Bell is that no Local Realistic theory can produce the QM results. So both of these - Locality and Realism - must be present explicitly as assumptions.
It seems to me that there are two steps involved: One (having nothing to do with locality, but instead is the Reichenbach's Common Cause Principle (whether or not Bell intended this). It's the assumption that if two things are correlated, then there exists a "common cause" for both. I gave the example earlier of twins: You randomly select a pair of 15-year-old twins out of the population, and then you separately test them for their ability to play basketball. Doing this for many pairs, you will find (probably--I haven't done it) that their abilities are correlated. The probability that they both are good at basketball is unequal to the square of the probability that one of them is good at basketball. Reichenbach's Common Cause Principle would imply that there is some common causal factor affecting both twins' basketball-playing abilities. Maybe it's genetics, maybe it's parenting style, maybe it's where they live, maybe it's what school they went to, etc. If we let ##\lambda## be the collection of all such causal factors, then it should be the case that, controlling for ##\lambda##, there is no correlation between twins' basketball-playing ability.
To me, that's where factorizability comes in. It doesn't have anything to do with locality, yet, because the common factors might conceivably include something happening on a distant star a billion light-years away. Locality is the additional assumption that the common causal factors ##\lambda## must be in the intersection of the backwards light cones of the two tests of the boys' basketball-playing ability.
Factorizability is not particularly about locality, but locality dictates what can go into the common factors.
