B Does the Laplace operator equal the Del operator squared?
The Laplace operator, represented as Δ, is equivalent to the divergence of the gradient operator, denoted as ∇². This relationship can be derived from the definitions of these operators, confirming that Δ = ∇·∇. The discussion also explores a specific equation involving fields σ and h, questioning how to solve it to derive σ = m ln h. The importance of using Cartesian coordinates for simplicity in differential operator properties is emphasized, as they allow for straightforward calculations. Overall, the thread clarifies the mathematical relationships between these operators and their applications in field equations.
Safinaz
TL;DR Summary
Dose Laplace operator ##\Delta## equal nabla operator squared ## \bigtriangledown^2## ?
Hello ,
The Laplace operator equals
## \Delta = \frac{\partial^2}{\partial x^2} + \frac{\partial^2}{\partial y^2} + \frac{\partial^2}{\partial z^2} ##
so does it equal as well nable or Del operator squared ## \bigtriangledown^2## ?
where
## \bigtriangledown =\frac{\partial}{\partial x} { \bf x} + \frac{\partial}{\partial y} { \bf y} + \frac{\partial}{\partial z } { \bf z}
Edit:
Now about this equation## \Delta \sigma + \frac{1}{2} \partial_\mu \sigma \partial^\mu \sigma = \frac{3}{2} e^{-2\sigma} \partial_\mu h \partial^\mu h ##
where ##\sigma## and ##h## are fields, and m and n are constants. I wonder how this equation to be solved to give ##\sigma = m ~ln h## as given by equations : (21), (23) in Paper
\Delta = \vec{\nabla}\cdot \vec{\nabla} is a notational convention
Indeed ##\Delta=\vec{\nabla} \cdot \vec{\nabla}##. It's not a convention but can be derived from the meaning of the operators, which is independent on the chosen basis and coordinate system, because it is a vector operator. The nice thing of this fact is that you can always use the most convenient basis for your problem. For general properties of the various differential operators Cartesian coordinates are the most simple ones. So let ##\vec{e}_k## (##k \in \{1,2,3 \}##) be a right-handed Cartesian basis, for which ##\vec{e}_k=\text{const}## and ##\vec{e}_1 \times \vec{e}_2=\vec{e}_3##.
Then the gradient of a scalar field is defined by
$$\vec{\nabla} \Phi=\vec{e}_k \partial_k \Phi,$$
where you have to some over ##k=1 \ldots 3## (Einstein summation convention). This is a vector field expressed with help of the Cartesian basis and its components wrt. this basis.
Now it is immediately clear that by taking the formal scalar product of ##\vec{\nabla}=\vec{e}_k \partial_k## with this vector field you get another scalar field,
$$\vec{\nabla} \cdot \vec{\nabla} \Phi = (\vec{e}_j \partial_j) \cdot (\vec{e}_k \partial_k \Phi) = (\vec{e}_j \cdot \vec{e}_k) \partial_j \partial_k \Phi = \delta_{jk} \partial_j \partial_k \Phi,$$
where
$$\delta_{jk}=\begin{cases} 1 & \text{for} \quad j=k, \\ 0 & \text{for} \quad j \neq k. \end{cases}$$
So finally you get
$$\vec{\nabla} \cdot \vec{\nabla} \Phi = \partial_j \partial_j \Phi = (\partial_1^2 + \partial_2^2 + \partial_3^2) \Phi=\Delta \Phi.$$
where
So finally you get
Hello, thanks for the answer. May you please see the edit to the question.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
