MHB Does the magnitude of covariance have any real meaning?
The discussion centers around the understanding of covariance and its formula, specifically the logic behind the numerator, which involves multiplying the deviations of two variables. It highlights that a positive product occurs when both values are either positive or negative, indicating a positive co-variation. However, a single covariance value lacks intuitive meaning without context or comparison, unlike variance or standard deviation, which can be understood as average deviations from the mean. The conversation emphasizes that covariance values are more meaningful when compared to one another. Ultimately, the difficulty lies in grasping the standalone significance of covariance.
dhiraj
The title of the question may not be clear. But that is the real difficulty I am facing. I am not able to understand logic behind coming up with this formula for covariance.
We know that the sample covariance formula is:-
[math]cov(x,y)=\frac{\sum(x_i - \bar{x})(y_i - \bar{y})}{n-1}[/math]
I am not able to understand the logic behind the numerator. Why are we multiplying the terms. I mean, I know we need to find the change in x is appearing along with change in y (if they co-vary), so this formula will give direction of that change in terms of sign of the number that you get after substituting the values in the formula. And also we will be able to compare e.g. Having covariance of 50 for example is more of proof of x and y moving together than having it as 30. So their order will make sense. But if you just think of a single value of covariance without having to compare it with anything else, does it have any real intuitive meaning (just the number in itself)? For example in case of variance or standard deviation one can easily see that it is average number of 'deviation from the mean' per data point in the sample. But here in case of covariance, I am not able to come up with any such intuitive understanding.
Mathematics news on Phys.org
Hi dhiraj! Welcome to MHB! (Smile)
It seems you already know.
If both values in the numerator are positive they provide a positive product.
And if both values are negative they also provide a positive product.
So if the values co-vary in a positive sense, we'll get a strong positive value, as we should.
A single value does indeed not make much sense.
We cannot derive a covariance, and neither for that matter, can we derive a standard deviation (for the same reason).
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
