Does the Observer have anything to do with conscious choice
In summary, the conversation discusses different perspectives on the role of the observer in causing the collapse of the wave function in quantum physics. The Copenhagen interpretation suggests that observation is when a quantum system leaves a mark in the macro world, while the modern view is that observation is a form of entanglement and the everyday classical world exists because it is constantly being observed and entangled with its environment. However, issues remain such as the factoring problem, where subjectivity is introduced into physics from the start and the exact definition of "environment" is subjective. Further research and key theorems are needed to fully understand the role of observation and decoherence in quantum mechanics.
  • #36
bhobba said:
I am not sure you are up on exactly what the relational interpretation is saying. Wikipedia gives a nice account:
http://en.wikipedia.org/wiki/Relational_quantum_mechanics
For me its a bit redundant - my view of QM includes it anyway, its just not stated explicitly - its more or less understood its like that. And its only of any concern prior to decoherence which generally occurs very very quickly meaning all observers agree on it after that. You undoubtedly can cook up situations where it's not like that but they in general are not what we see in the everyday world around us.
l
I have read that paragraph, but maybe I'm not understanding it. If you are saying "its more or less understood that it's like that" (which is what I think), why does it have a separate heading? And the description doesn't seem to say it is "like that". Or, is that just your personal view?
The thing I keep getting back to is the interaction of two particles, like an electron and a proton. That interaction gives rise to the probabilities associated with a subsequent observation. But the two particles are interacting, so must be observing each other. The proton "knows" more about the electron than we do since it is interacting and affecting it. We know about the pair as a probability distribution until we actually observe it. That, to my ignorant mind, seems to drive one to a relational interpretation.
  • #37
Different interpretations emphasize different things. Just because one interpretation chooses not to worry about it doesn't meant it doesn't agree with it. It's just not important IMHO because decoherence occurs very very quickly and all observers agree on the resultant mixed state.
For some reason you don't seem to get an observation is something that leaves a mark here in the macro world.
Thanks
Bill
  • #38
Maui said:
A system's information capacity has what to do with its probability for a given measurement outcome?
Measurement outcomes convey information. The actual values of an outcome are arbitrary - its the information it conveys that is important. Think of the Stern-Gerlach experiment. It has spin up or down. That coveys a bit of information - what we call the bit on and off is irrelevant. But to be clearer its equivalent to saying systems that are observationally equivalent are equivalent. Information seems to be the buzzword in physics these days. What it means here is since an improper mixed state is observationally the same as a proper one then by the axiom they are equivalent - measurement problem solved.
Thanks
Bill
  • #39
It would be even more clear if we could specify what we mean by a "system". Different axiomatizations may mean different things. Do we mean a "single object" or an "ensemble of objects"?
And under what conditions? People using the same word "system" but with different meaning or undefined at all will argue without realizing that they are talking about different things.
So, one should define "system", "observationally equivalent", "equivalent".
  • #40
arkajad said:
It would be even more clear if we could specify what we mean by a "system". Different axiomatizations may mean different things. Do we mean a "single object" or an "ensemble of objects"? And under what conditions? People using the same word "system" but with different meaning or undefined at all will argue without realizing that they are talking about different things. So, one should define "system", "observationally equivalent", "equivalent".
See the paper I linked to before where the 3 axioms came from. That paper is a bit sloppy but when read with Hardy's seminal paper its a lot clearer:
http://arxiv.org/pdf/quant-ph/0101012v4.pdf
But the terms you mention seem pretty clear.
Can I ask you a question? Is your background math/physics or philosophy? In my experience people that get hung up on what at least seems to me pretty obvious semantics are more likely into philosophy. Its the same sort of stuff you see when people think observation implies an observer. The better books like Dirac and Ballentine are rather careful to use the term measurement instead of observer but once you understand what's meant its not confusing.
Thanks
Bill
  • #41
Axiom 5 (in Hardy, 3 in yours) involves the term "pure state" that has not been defined.
To get my math/physics degree I had to pass an exam in philosophy as well.
  • #42
arkajad said:
Axiom 5 involves the term "pure state" that has not been defined.
It's a standard term in QM and probability theory.
It means a state that can't be expressed as the convex sum of other states. In probability theory that would be the possible outcomes and in QM a state (here state is the general state defined by Von Neumann being a positive operator of unit trace) with only one eigenvector.
My background is applied math so I am not that sensitive to what others think of as semantic imprecision.
Thanks
Bill
  • #43
Where is the proof that the set of states is a convex set? It should precede the use of the term "pure state".
  • #44
Its a definition - no proof required.
These are standard terms.
Thanks
Bill
  • #45
Where do you need that the set of state is convex in order to define pure states?
  • #46
Its in Ballentine page 50 Section 2.3 - its a very simple theorem from the definition of a pure state proven on p52. A state is pure iff it can't be expressed as the convex sum of other states.
Scratching my head why standard stuff like this needs to be explained.
Thanks
Bill
  • #47
This is what boobba wrote:
"It means a state that can't be expressed as the convex sum of other states."
"Its a definition - no proof required."
But I do not see the term "convex" in the definition.
  • #48
bhobba said:
Its in Ballentine page 50 Section 2.3 - its a very simple theorem form the definition of a pure state proven on p52. A state is pure iff it can't be expressed as the convex sum of other states.
Thanks
Bill
Sure, I know perfectly what a pure state is. But I fail to see why you need to prove that the states form a convex set in order to define a pure state. A pure state is a state that can't be expressed as the nontrivial convex combination of other states. Nowhere is needed that the states actually do form a convex set.
Sorry if I'm being pedantic.
  • #49
But I am not asking about Belinfante's set of axioms. I am asking about about sets of axioms in the two mentioned papers.
  • #50
It's OK. One should first define "convex combination of states" starting with the axioms and only with them. Otherwise why would we need axioms?
  • #51
OK, but don't you think that the concept of "convex combination" is well known to everybody reading this paper. I mean, convex combinations don't even have anything to do with QM, they are rather a mathematical concept.
  • #52
Its dead simple. Look the outcomes with dead certainty are unit vectors. These are the pure states of probability theory. A vector with positive entries that adds up to one is a probability vector. Only the vectors with unit entries can't be expressed as a convex sum of other vectors. I suppose no proof required might be a little off the mark - but not by much - it's rather trivial.
Both those papers are a bit like that - they are somewhat of a slog to go through in that if you haven't come across these terms before it may take a bit of getting used to.
Thanks
Bill
  • #53
My bad. Like I say my background is in math so I guess stuff that's common in math I take more or less as given.
Both those papers are of the mathematical physics variety so that sort of terminology tends to be rampant.
Thanks
Bill
  • #54
Convex combination of "what"? Of two real numbers? I know. Of two trees? I do not know, because I do not know how to add trees and multiply them by numbers to get other trees. The same with "states"? State has been introduced in the axioms. But no operations on state have been discussed. Neither the meaning of these operations.
  • #55
Scratching head - of probability vectors.
Thanks
Bil
  • #56
Well, since a state is defined as a certain operator, I think it's not difficult to infer that we take the sum and scalar multiplication of operators as defined in mathematics. If somebody doesn't know how to add two operators, then I don't think he should be reading this paper.
I mean, it's clear this paper takes for granted the required math such as linear algebra/functional analysis. So we should read the paper with that in mind. Otherwise, the paper would be far too long, as they would also need to explain what hermitian is and what the trace is.
  • #57
micromass said:
Well, since a state is defined as a certain operator.
Definition of "State" from Hardy's paper:
"The state associated with a particular preparation is defined to be (that thing represented by) any
mathematical object that can be used to determine the probability associated with the outcomes of any measurement that may be performed on a system prepared by the given preparation."
So it is not defined as an operator.
And then we have
"Axiom 5 Continuity. There exists a continuous reversible transformation on a system between any
two pure states of that system.
The first four axioms are consistent with classical probability theory but the fifth is not (unless the
word “continuous” is dropped). "
Nowhere in the axioms we have operators.
  • #58
Its a definitional thing. Given a measurement setup with outcomes yi like they have in the paper one defines the operator associated with the setup as Ʃ yi |bi><bi| for some |bi> not yet determined (they are the states that are the possible outcomes). This is the first axiom of the treatment you find in Ballentine. The second axiom in Ballentine, Born's rule, is what the paper is concerned about - it really is the key axiom. It's a very interesting thing that QM basically depends on just these two axioms. And also a very interesting thing that you can start with the first axiom as a definition (of course you need to justify why you would want such a cockeyed definition in the first place - but that's another story) and derive the second via Gleason's theorem with the assumption of non-contextuality. When people ask me what's the simplest way of viewing QM so it doesn't look like its pulled out of a hat its what I tell them. At its foundations, when viewed the right way, QM is quite natural - but only when viewed the right way.
Although I haven't seen it, and need to check them out when I get a bit of time, I am sure a lot of this stuff is in the video lectures on a course in Quantum Foundations the Perimeter Institute have archived:
http://www.pirsa.org/C12002
Because its something that really interests me I sometimes forget it not as well known as perhaps it should be. This is one of the reasons I am such a big fan of Ballentine - he develops QM this way from the start and examines closely exactly what it means.
Thanks
Bill
  • #59
I totally get what you are saying, but it is a relative thing (relational). My "here in the macro world" is different than a particle's "here in the macro world". When two particles interact, what happens? Did one particle leave its mark on the other, or not? Yet to us they are still represented by wave functions.
Actually, I have a problem with the phrase "here in the macro world" as if there is some other world. Where is "there in the non-macro world"? Seems there is one world that things exist in, and our knowledge about them is limited, so we express what we know as a probability: the probability of what we might measure when we really pin it down. Relational interpretations are saying that different entities can see different things about an objects state or potential measurable state. One might see it as a superposition, and the other might not. ("for example, to one observer at a given point in time, a system may be in a single, "collapsed" eigenstate, while to another observer at the same time, it may be in a superposition of two or more states."
And this isn't limited to the micro world:
"However, it is held by relational quantum mechanics that this applies to all physical objects, whether or not they are conscious or macroscopic."
I just want to understand two interacting particles that I have not observed but know things about as a pair. How does each particle view the other particle. How is that view different than how I view the pair. They obviously have to be consistant, but not neccessarily the same.
Sometimes you seem to take a pure instrumentalist view, that these things are beyond QM, but then other times you acknowledge there is something more.
  • #60
A mark is something visible here in the macro world. Obviously particles interacting do not do that. When they interact you consider their tensor product and via their interaction Hamiltonian they become entangled - that's the very essence of entanglement.
Basically for particles to leave a mark they need to interact with a macro object. It becomes entangled with the macro object and leaves a mark. QM is a theory about such marks. What its doing or any other visualizations like particles leaving marks on other particles are not part of the theory. Sure it can become entangled with it but that is entirely different to being measured, leaving a mark, observed or the other words bandied about.
Can I suggest you study a book like Ballentine so you know the detail of this sort of stuff?
Or at least have a look at Susskinds lectures on it:
http://theoreticalminimum.com/courses/quantum-entanglement/2006/fall
Thanks
Bill
  • #61
It's by definition the world of everyday experience. There is obviously another level - namely the world of atoms and their constituent particles. We know of their existence by the outcomes of measurements we make that leave traces in the everyday world. QM is a theory about those traces - that's it, that's all.
We have the issue of why the world of everyday experience behaves the way it does since its composed of that quantum stuff, and that is a deep issue - but a lot of progress has been made.
I am an applied mathematician - these kind of word games like where is there a non macro world sound suspiciously like philosophy and if that's what interests you then it might be better looking elsewhere for answers. Guys like me tend to take literal commonsense views of words without getting caught up in these types of semantics.
I think you misunderstand because you are confused with a state; thinking its something more than a codification of the outcomes of observations. People talk of a quantum state in a literal sort of way and because of that you think its the reality - but its not implying its anything more than what I have said it is. When two particles interact the description is about its quantum state (specifically the tensor product of the states of the particles) which codifies the outcomes of observations - but its not being observed so its not telling us anything more.
I have carefully explained what an observation is, its clearly and obviously not applicable to two particles interacting yet you continue to use words like one particle viewing another. View, observe measure etc etc are in this context not applicable to states. Why do you do that?
Imagine speaking to an actuary that talks pretty freely about mortality rates, contingencies etc etc. Then ask them - how does a contingency view a mortality rate - you are likely to get strange looks.
I am not into philosophy but am reminded of Wittgenstein: 'Whereof one cannot speak, thereof one must be silent'
Thanks
Bill
  • #62
Which is a pure instrumentalist view with no room for any interpretations.
I understand what QM is as much as I can without understanding QM. Interpretations exist above (or below depending on your semantics) hard instrumentalist QM.
You seem to take issue with relational interpretions,
"for example, to one observer at a given point in time, a system may be in a single, "collapsed" eigenstate, while to another observer at the same time, it may be in a superposition of two or more states." and "However, it is held by relational quantum mechanics that this applies to all physical objects, whether or not they are conscious or macroscopic." which are both from the wikipedia paragraph.
I didn't realize that when a proton and an electron interacted as a hydrogen atom that they became entangled. Or two hydrogen atoms interacting become entangled.
  • #63
bhobba said:
Its a definitional thing. Given a measurement setup with outcomes yi like they have in the paper one defines the operator associated with the setup as Ʃ yi |bi><bi|/QUOTE]
I am not talking about Ballentine's axioms. I am talking about axioms 1-5 or 1-3 in the quoted papers. The operation Ʃ yi |bi><bi| is undefined in these axiom systems. So what is the point of using "axiomatic approach" if you are not following the axiomatic way?
Of course I know what is a pure state in the usual standard approach. Do you want to say: we are assuming, from the very beginning the standard formalism of QM where "states" are in one to one correspondence with density matrices and pure states by one-dimensional projection operators? Or: states are represented by normalized positive functionals on a von Neumann (or, perhaps, C*) algebra? But if so, why it is not written in the preamble to these papers? I really would like to know the point of taking this axiomatic approach.
  • #64
No its not. They prove the existence of a Quantum state as the element of a complex Hilbert space from which the definition is well defined.
Also see section 8.7 of Hardy's paper where operators are introduced.
'Hence, we obtain pmeas = trace(Aˆρˆ) (90) which is shown to be equivalent to pmeas = r · p in section 5. We now need to prove that the restrictions from quantum theory on Aˆ and ρˆ follow from the axioms. Both ρˆ and Aˆ must be Hermitean since r is real.'
Thanks
Bill
  • #65
bhobba said:
No its not.
The term should be defined before it is introduced in the axioms. Not after. Otherwise axioms do not make any sense. Unless it is a primitive term. But that option does not make sense in this context either.
And it would be not too difficult to do it. Except that the question whether we can distinguish operationally between mixed and pure states leads to a rather nontrivial discussion. Compare the related conclusion in Belinfante's "Can One Detect the State of an Individual System?", Foundations of Physics, Vol. 22, No. 3, 1992.
Jauch and Piron understood the problems. But Hardy apparently is not paying sufficient attention to the logical consistency of his "axiomatic approach".
  • #66
It is.
I don't know why but for some reason you are having a lot of trouble understanding what is in plain sight. In section 8.7, A, the operator associated with the observation, is defined before the standard trace formula is deduced.
This paper has been around for quite a while and Hardy is a very well respected physicist working on the foundations of QM. Its highly unlikely he would make fundamental errors of that nature.
Thanks
Bill
  • #67
I am pointing out the error. Whether someone is highly respected or not is not relevant. I am interested in the consistency of the axiomatic system, and not whether some person is respected or not. Highly respected (and for the right reasons) people were making errors. It is not unusual.
Of course one may ask whether the error is an important one or is it just inessential detail. I would not be making such an issue if I would think it is just "an easily correctable omission". In my view fixing this error would require an essential rewrite of the whole paper, including the conclusions.
  • #68
The point is there is no error. The operator A associated with the observation is defined BEFORE use in the key trace formula.
My comment was not an appeal to authority, I was merely pointing out it has been gone over countless times - fundamental errors like that would be picked up early. It's more likely you missed something, which I think you have.
Thanks
Bill
  • #69
The point is that there is an error. Because the term "pure state" is being used in Axiom 5, before it has been defined. It does not matter that it is defined "somewhere else". Axiomatic systems are being used for definite purposes and have their rules. Do we want to abandon logic in mathematical physics? I would not vote for this. It would be a shame.
I know of fundamental errors that have not been detected quickly.
  • #70
What a pure state is defined in the framework of generalized probabilistic theories of which bog standard probability theory and QM are just examples eg:
http://www.cgogolin.de/downloads/gpt.beamer.pdf
'Definition: States that can not be written as a convex combination of states are called pure or extremal.'
Its just you haven't come across it before. I agree it's not the stuff that's generally taught to mathematicians and physicists but people into the area of quantum foundations know of it. Axiom 5 differentiates the pure states of normal probability theory from those of Quantum Theory. Both are theories under the heading of generalized probabilistic theories for which the concept of pure state is applicable. But the class of theories for which the concept applies is much wider eg QM like theories based on real vector spaces and quaternion spaces.
If you don't get this then its really only going to continue going around in circles.
Thanks
Bill
