Does there exist a 2x2 non-singular matrix with only one 1d eigenspace?
zenterix
How do we find a matrix ##A## whose only eigenvectors are multiples of ##(1,4)## and that is invertible?
Let's try to find a ##2\times 2## matrix. Suppose the matrix ##A## is given by
$$A=\begin{bmatrix}a&b\\c&d\end{bmatrix}$$
Since we have only a single 1d eigenspace for this matrix, there can only be one eigenvalue, ##\lambda##.
We know this eigenvalue cannot be 0 since the matrix is non-singular.
Before going through calculations/reasoning, let me summarize what my questions will be
- In order to obtain the desired matrix, I impose five constraints on ##a,b,c,d,## and ##\lambda##.
- These five constraints are four equations and an inequality. I am not sure how to work with the inequality.
- I can leave the inequality out and solve the system of four equations for five unknowns.
- By guessing values together with the solution to these four equations, I can eventually reach the desired matrix.
- However, in this process of guessing it became clear that one constraint is definitely missing: the equations I have guarantee solutions (ie, matrices) with a sole eigenvalue; but they don't guarantee an eigenspace with only a single dimension.
- I would like to know how to add this constraint.
Now let me go through my reasoning.
$$\begin{vmatrix} a-\lambda & b\\ c & d-\lambda \end{vmatrix}=0\tag{2}$$
$$\lambda^2-\lambda(a+d)+(ad-bc)=0$$
which has discriminant
$$\Delta=(a+d)^2-4(ad-bc)=0\tag{3}$$
We equate ##\Delta## to zero because we there to be a single ##\lambda##.
Thus
$$\lambda=\frac{a+d}{2}\tag{4}$$
We have three further constraints on the variables.
First, ##A## is non-singular if
$$ad-bc\neq 0\tag{5}$$
In addition, ##A(1,4)=\lambda (1,4)## so
$$a+4b=\lambda\tag{6}$$
$$c+4d=4\lambda\tag{7}$$
At this point, equations (3), (4), (5), (6), and (7) are five constraints and we have the five unknowns ##a,b,c,d,## and ##\lambda##.
One of the constraints is an inequality, however.
Suppose I leave out the inequality and just solve (3), (4), (6), and (7). Using Maple, I get the solution
$$a$$
$$b=\frac{d-a}{8}$$
$$c=2(a-d)$$
$$d$$
$$\lambda=\frac{a+d}{2}$$
If I let ##a=d=1## then it turns out that ##b=c=0##. Thus, matrix is the identity matrix.
The problem is that the eigenspace for the sole eigenvalue of ##1## is 2-dimensional not 1-dimensional as desired.
By guessing values, I was able to obtain a matrix with all the desired constraints.
Let ##a=2##, ##d=3##. Then ##b=\frac{1}{8}## and ##c=-2##.
Thus, the matrix is
$$\begin{bmatrix} 2& \frac{1}{8}\\-2 &3\end{bmatrix}$$
We have ##ad-bc=\frac{25}{4}\neq 0## so the matrix is invertible.
The sole eigenvalue is ##\frac{5}{2}## and the eigenspace is the span of ##(1,4)##.
My questions are
1) how do I guarantee that my solution (ie, the matrix ##A##) will have one eigenspace only, and this eigenspace is one-dimensional? What additional constraint do I need in the system of equations?
2) how do I work with a constraint that is an inequality?
The eigenspace corresponding to ##\lambda## is the solution space of ##A-\lambda E=0## (i.e ##\mathrm{Ker}(A-\lambda E))##. What you are currently after is that
<br /> \left(\begin{array}{cc}a-\lambda &amp;b \\ c&amp;d-\lambda \end{array}\right)<br />
is of rank one i.e that the determinant is zero and at least one of the entries in the above is nonzero. Then you further require that
<br /> \left(\begin{array}{cc} a&amp;b\\c&amp;d \end{array}\right)\left(\begin{array}{c}1\\4 \end{array}\right) = \lambda \left(\begin{array}{c}1\\4 \end{array}\right)<br />
There is no inequality restriction at play here. You correctly deduce that ##\lambda = \frac{a+d}{2}## because there can only be one eigenvalue. So we have
<br /> \begin{cases}(a-\lambda)(d-\lambda) - bc = 0 \\ a+4b = \lambda \\ c+4d = 4\lambda \\ a+d = 2\lambda \end{cases}<br />
We have four conditions and five variables. Since you didn't restrict the eigenvalue we'll pick one. Since ##A## is nonsingular, we must pick ##\lambda \neq 0##. So let's pick ##\lambda = 1## for instance. Thus, we simplify to
<br /> \begin{cases}<br /> 1-(a+d)+(ad-bc) = 0 \\<br /> a+4b=1 \\<br /> c+4d = 4\\<br /> a+d=2<br /> \end{cases}<br />
We can temporarily ignore the first condition, because it's not linear. The other three conditions give us
<br /> \left(\begin{array}{cccc|c} 1&amp;4&amp;0&amp;0&amp;1 \\ 0&amp;0&amp;1&amp;4&amp;4 \\ 1&amp;0&amp;0&amp;1&amp;2 \end{array}\right)<br />
The solutions for this are
<br /> \left(\begin{array}{c}a\\4b\\c\\d \end{array}\right) = \left(\begin{array}{c}2-s \\ -1+s \\ 4-4s \\ s \end{array}\right),\quad s\in F.<br />
So all that's left is to plug it in the nonlinear condition and solve the resulting quadratic and that will determine what ##A## could be if we assumed that ##\lambda =1##. It could also be that the quadratic has no solutions in which case try another ##\lambda##.
edit: It turns out plugging in the solution to the nonlinear condition yields ##0=0##, so pick any ##s## and fire away.
Instead of fixing the eigenvalue, we could also fix one of the entries of ##A## such that ##A-\lambda E## is of rank one.
Picking ##s=0## in the above gives us
<br /> A=\left(\begin{array}{cc} 2 &amp; -\frac{1}{4} \\ 4 &amp; 0\end{array}\right),<br />
which is clearly nonsingular with characteristic polynomial ##(\lambda-1)^2## as expected and the system
<br /> A-E = \left(\begin{array}{cc}1 &amp; -\frac{1}{4} \\ 4 &amp; -1\end{array}\right)<br />
is clearly of rank one whose solutions are generated by ##(1,4)##.
Do we not have that the Jordan normal form of A is \begin{pmatrix} \lambda &amp; 1 \\ 0 &amp; \lambda \end{pmatrix}? The first basis vector is (1,4)^T and the second can be any linearly independent vector - say (0,1)^T. Then <br /> \begin{split}<br /> A \begin{pmatrix} 1 \\ 4 \end{pmatrix} &amp;= \lambda \begin{pmatrix} 1 \\ 4 \end{pmatrix} \\<br /> A \begin{pmatrix} 0 \\ 1 \end{pmatrix} &amp;= \lambda \begin{pmatrix} 0 \\ 1 \end{pmatrix} + \begin{pmatrix} 1 \\ 4 \end{pmatrix} \end{split} and \begin{split}<br /> A\begin{pmatrix} x \\ y \end{pmatrix} &amp;=<br /> A\left(x\begin{pmatrix} 1 \\ 4 \end{pmatrix} + (y - 4x) \begin{pmatrix} 0 \\ 1 \end{pmatrix} \right)\\<br /> &amp;= x\lambda \begin{pmatrix} 1 \\ 4 \end{pmatrix} + (y - 4x) \left( \lambda \begin{pmatrix} 0 \\ 1 \end{pmatrix} + \begin{pmatrix} 1 \\ 4 \end{pmatrix} \right) \end{split} giving <br /> A = \begin{pmatrix} \lambda - 4 &amp; 1 \\ -16 &amp; \lambda + 4 \end{pmatrix}.
Likes nuuskur and fresh_42
