MHB Does this count as a proof for the infimum?
  • Thread starter Thread starter NoName3
    Count Proof
NoName3
24
I want to know whether the following the counts as a proof that infimum of the set $S =
\left\{2(-1)^n+\frac{5}{n^2+2}: n \in \mathbb{N}^{+} \right\}$ is $\text{inf}(S) = -2$.
Let $A \subseteq X$, where $X$ is some ordered field. Then $\text{inf}(A)$ is $m \in X$ such that for any $x \in A$ we have $m \le x$ and for any number $k \in X$ such that $k \le x$ we have $k \le m$. I'm not sure as to whether what's below misses the second part of the definition. So, is it enough?
Let $\displaystyle x_n = 2(-1)^n+\frac{5}{n^2+2}$, then $\displaystyle x_{2n} = 2+\frac{5}{(2n)^2+2}$ and $\displaystyle x_{2n+1} = \frac{5}{(2n+1)^2+2}-2$.
Let $j = 2n$ then $\displaystyle x_{j} = 2+\frac{5}{j^2+2}> 2+\frac{5}{(j+1)^2+2} = x_{j+1}.$ Thus $x_{j} > x_{j+1}.$ Hence $x_{j}$ is strictly decreasing from $\dfrac{11}{3}$ to $2$. Similarly, let $k = 2n+1$ then $\displaystyle x_k = \frac{5}{k^2+2}-2 >\frac{5}{(k+1)^2+2}-2$$ = x_{k+1}.$ Hence $x_k$ is strictly decreasing from $-\dfrac{1}{3}$ to $-2$. Hence we have $\min(-2, 2)<x_n < \max(11/3, -1/3)$ which implies that $-2<x_n < \dfrac{11}{3}$. Thus $\text{inf}(S) = -2.$ Is this correct, do I've to use $\epsilon-\delta$ proof?
The concept of infimum is defined on any (partially) ordered set.
This is not stated very well. The scope of the universally quantified $x$ is the clause "we have $m \le x$". After that, the scope closes and $x$ is no longer defined. Therefore, the second occurrence of $x$, namely, in the phrase "such that $k \le x$", requires its own universal quantifier. Note also that the scope of this second quantifier does not last until the end of the sentence, but only includes "$k \le x$". Formally,
m=\inf A\iff (\forall x\in X\; m\le x)\land (k\le x\implies k\le m)
is incorrect because the occurrence of $x$ in $k\le x$ is undefined. Also,
m=\inf A\iff (\forall x\in X\; m\le x)\land \forall x\in X\;(k\le x\implies k\le m)
is incorrect because it has a different meaning. The correct statement is
m=\inf A\iff (\forall x\in X\; m\le x)\land ((\forall x\in X\;k\le x)\implies k\le m).
In words, it says, "$\inf A$ is $m \in X$ such that for any $x \in A$ we have $m \le x$ and for any number $k \in X$ such that $k \le x$ for all $x\in X$ we have $k \le m$".
The rest of the proof also has some flaws, so I'll write my variant. We have to prove $\forall x\in X\; (-2\le x)$ and $(\forall x\in X\;k\le x)\implies k\le -2$. For the first claim,
-2\le 2(-1)^n<2(-1)^n+\frac{5}{n^2+2}.
For the second one, suppose that $k\le x$ for all $x\in X$, but $k>-2$. Let $\varepsilon=k-(-2)>0$ and consider an odd $n>\sqrt{\dfrac{5}{\varepsilon}}$. Then
n^2>\frac{5}{\varepsilon}\implies n^2+2>\frac{5}{\varepsilon}\implies \frac{5}{n^2+2}<\varepsilon.
Therefore,
X\ni 2(-1)^n+\dfrac{5}{n^2+2}=-2+\dfrac{5}{n^2+2}<-2+\varepsilon=k.
We found an $x\in X$ such that $x<k$, which contradicts the assumption that $x\ge k$ for all $x\in X$.
Thank you, very helpful!
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of in the subspace topology.
