B Does this help solve the Riemann Hypothesis?
The discussion centers on the potential implications of a proposed equation involving the Riemann zeta function for solving the Riemann Hypothesis. It is asserted that the concept of an inverse zeta function is flawed, as the zeros of the zeta function do not correspond to a single value, making it impossible to define a proper inverse. The complexity of the inverse zeta function is emphasized, with caution advised against misinterpretations of its properties. Additionally, there is skepticism regarding the validity of the proposed equations, as they do not clearly solve for the real part of s. Overall, the conclusion is that the approach does not contribute to solving the Riemann Hypothesis.
MevsEinstein
TL;DR Summary
I created an equation with the real part of the input of the zeta function on the RHS and a complex expression on the LHS
Hello PF!
If ##\Re (s)## is the real part of ##s## and ##\Im (s)## is the imaginary part, then t is very easy to prove that $$\zeta (s) = \zeta ( \Re (s) ) \zeta ( \Im (s)i) - \displaystyle\sum_{n=1}^\infty \frac{1}{n^{\Re (s)}} [\displaystyle\sum_{k \in S, \mathbb{Z} \S = n} \frac{1}{k^{\Im(s)i}}]$$ Since the second term simplifies to ## \zeta ( \Re (s) ) \zeta ( \Im (s)i) - \zeta (s)##. (##\mathbb{Z} \S = n## is actually ##\mathbb{Z}## \##S
## = ##n##). Now, solving for ##\Re (s)## gets us $$\zeta^{-1} ({\frac{\zeta (s) + \displaystyle\sum_{n=1}^\infty \frac{1}{n^{\Re (s)}}[ \displaystyle\sum_{k \in S, \mathbb{Z} \S = n} \frac{1}{k^{\Im (s)i}}]}{\zeta (\Im (s)i)}}) = \Re (s)$$ Setting ##\zeta (s)## to zero gives us the equation we were looking for. Now I am thinking, could this help solve the Riemann hypothesis? Or will this just spit out ##\Re (s)##? I mean, the inverse zeta function is very complicated (page 43 of https://arxiv.org/pdf/2106.06915.pdf ), so it's hard to tell.
  • Skeptical
Likes weirdoguy and malawi_glenn
Mathematics news on Phys.org
The short answer is a simple no.
And there is no such thing as an inverse zeta-function. Let us assume for a second that there is ##\zeta^{-1}.## Then ##\zeta(s)=0## means ##s=\zeta^{-1}(\zeta(s))=\zeta^{-1}(0)##. However, there are infinitely many zeros of the zeta-function. How could that be just a single value ##\zeta^{-1}(0)?## The pre-image ##\zeta^{-1}(\{0\})## is an entire, infinite set. No way to make this a function.
You have to be careful with the zeta-function. E.g., ##\zeta(-1)=-\dfrac{1}{12}## but ##1+2+3+\ldots \neq -\dfrac{1}{12}.## I am not sure what you are doing here so I cannot comment your equations. If you want to even understand the Riemann hypothesis then you should study
https://www.physicsforums.com/insig...thesis-and-ramanujans-sum/#toggle-id-1-closed
Likes nuuskur, berkeman, malawi_glenn and 1 other person
To be fair, your first sentence beginning with
I created an equation..
is already alarming and strongly advises to ignore what follows. :frown:
Ignoring all other possible problems, how is this solving for ##\Re (s)##? It appears on both sides!
Oops, sorry about that.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
