MHB Does this imply infinite twins?
  • Thread starter Thread starter e2theipi2026
    Infinite
The discussion centers on the formulation of the twin prime counting function, expressed as π₂(n) = f(n) + π(n) + π(n+2) - n - 1. The argument posits that if the twin prime counting function becomes constant, it leads to a contradiction regarding the parity of the left and right sides of the equation. Specifically, the left side can vary in parity while the right side remains constant, suggesting that the twin prime counting function cannot be constant. This implies the existence of infinitely many twin primes. The conversation also seeks clarification on the function f(n), which counts twin composites, and its role in proving the Twin Prime Conjecture.
e2theipi2026
I can prove the twin prime counting function has this form:
\pi_2(n)=f(n)+\pi(n)+\pi(n+2)-n-1,
where \pi_2(n) is the twin prime counting function, f(n) is the number of twin composites less than or equal to n and \pi(n) is the prime counting function.
At n=p_n, this becomes
\pi_2(p_n) = f(p_n) + \pi(p_n) + \pi(p_n + 2) - p_n - 1.
With this form, can I make the following argument?: Assume the twin prime counting function becomes a constant c, then I can change the twin prime counting function to c in the equation. The prime counting function \pi(n) at the prime sequence p_n is just n, so I can change that to n. Because I'm assuming no more twin primes, p_n+2 is not a prime so \pi(p_n+2) will also become n, the equation directly above this paragraph can therefore be simplified to:
c = f(p_n) + 2n - p_n - 1.
Adding 1 to both sides of this and rearranging it gives,
p_n - f(p_n) = 2n - b, where b=c+1.
The right side of p_n - f(p_n) = 2n - b
has only one possible parity, either odd or even because it is an even number 2n minus a constant b.
But, the left side can be both odd and even many times over because f(p_n) can be odd or even and is subtracted from p_n which is odd for p>2.
So, the left side will change parity for different values of n, while the right side of the equation will remain one parity. Therefore, the two sides cannot be equal for all n.
This seems to show the twin prime counting function cannot become constant and therefore, there are infinite twin primes. Now assuming I can prove the form of the twin prime counting function given at the beginning of this question, does that argument hold water?
Mathematics news on Phys.org
What is the function $f(n)$?
f(n) was defined at the beginning of the post. If you mean more detail, it is counting the number of "smaller" twin composites \le n. So, it is counting all composite k\le n such that k+2 is also composite.
It would seem what I have shown is that the Twin Prime Conjecture is equivalent to proving that f(p_n) changes parity an infinite number of times. Any ideas? :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
