Does water electrolysis work efficiently under high pressure?
The discussion centers on the feasibility of integrating electrolysis within a high-pressure hydrogen tank to eliminate the need for energy-intensive compression after hydrogen production. It raises questions about whether electrolysis requires more energy at higher pressures, potentially offsetting the energy savings from avoiding compression. The conversation highlights the importance of understanding compressor efficiency and heat losses during operation. It also mentions that balancing pressures during electrolysis could be achieved with a separating barrier, ensuring that gas production rates on both electrodes are proportional to maintain liquid levels. The equilibrium voltage's dependence on hydrogen and oxygen partial pressures is noted, indicating that pressure conditions can influence electrolysis efficiency.
arusse02
One of the stages in hydrogen production after electrolysis is to run the hydrogen through a compressor and that can take a lot of energy. Would it be possible to run an electrolysis setup inside an already high pressure hydrogen tank so that the hydrogen being separated during the electrolysis immediately stays in the high pressure area instead of needing to be compressed?
Or does electrolysis use more and more energy the higher pressure the external environment is such that it would match the energy used during the compression stage?
I'm assuming there is some mechanism to separate both the oxygen and hydrogen into equally high pressure tanks such that the pressure was balanced.
Chemistry news on Phys.org
You got it; not as elegant a statement as a thermodynamicist would make, but it's all there.
How efficient are the compressors? How big are the losses to heat in compressor operation?
The equilibrium voltage depends on hydrogen and oxygen partial pressures - slightly.
Balancing the pressures would be easy. Just use a separating barrier partway down. If you do not want the level of liquid to change, make the free areas on both electrodes side proportional to gas production.
I came.across a headline and read some of the article, so I was curious. Scientists discover that gold is a 'reactive metal' by accidentally creating a new material in the lab https://www.earth.com/news/discovery-that-gold-is-reactive-metal-by-creating-gold-hydride-in-lab-experiment/ From SLAC - A SLAC team unexpectedly formed gold hydride in an experiment that could pave the way for studying materials under extreme conditions like those found inside certain planets and stars undergoing...
  • · Replies 19 ·
12K
  • · Replies 16 ·
