Does Zero Linear Momentum Always Mean Zero Kinetic Energy?
The discussion clarifies that while zero kinetic energy in a system of particles implies zero linear momentum, the opposite is not true; a system can have zero linear momentum while still possessing kinetic energy. Examples provided include two particles moving in opposite directions, resulting in zero momentum but non-zero kinetic energy. The conversation also touches on angular momentum, questioning if similar principles apply. Participants explore the implications of kinetic energy and momentum in a system treated as a single object, emphasizing that kinetic energy cannot be negative. Overall, the thread highlights the distinct relationship between kinetic energy and linear momentum in physics.
AdityaDev
"if kinetic energy of system of particles is zero, then linear momentum of that system of particles is zero but the reverse is not true. That is if linear momentum of a system of particles is zero, then the kinetic energy may not be zero"
This is what I got from my text. Can you provide me with some examples because I am a bit confused. Can you provide some explanation?
Is this true for angular momentum?
Consider two particles with mass m, one with velocity +v and one with velocity -v.
Likes AdityaDev
So momentum is zero and kinetic E is not zero. Can you give an example for kinetic energy zero and momentum non zero?
KE = sum of 1/2 mv2. Can any of those terms be negative?
Or, imagine covering the whole system with a curtain or box and treating it as one object of total mass M and velocity V.
P=MV, while KE= 1/2MV2+ KE(within system, relative to the center of mass)
If KE = 0, what does that imply? Assume masses are never negative.
Likes AdityaDev
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
