find_the_fun
- 148
The question asks
Verify that the indicated function \(\displaystyle y=\phi(x)\) is an explicit solution of the given first order differential equation. Consider \(\displaystyle \phi\) simply as a function, give its domain. Then by considering \(\displaystyle \phi \)as a solution of the differential equation, give at least one interval \(\displaystyle I\) of definition.
\(\displaystyle (y-x)y'=y-x+8\); \(\displaystyle y=x+4\sqrt{x+2}\)The first step in solving a problem is understanding the question.
\(\displaystyle 4\sqrt{x+2}+\frac{16\sqrt{x+2}}{2\sqrt{x+2}}=4\sqrt{x+2}\) and got a little worried. This equality is only true when x=-2.
The answer key gives: domain of fuctnion is \(\displaystyle [-2, \infty)\); largest interval of definition for solution is \(\displaystyle (-2, \infty)\)
Understood.Verify that the indicated function \(\displaystyle y=\phi(x)\) is an explicit solution of the given first order differential equation.
Is it asking where the function \(\displaystyle x+4\sqrt{x+2}\) is defined?Consider \(\displaystyle \phi\) simply as a function, give its domain.
What is an interval of definition?So I took the derivative of y and was verifying the solution and got to the equationThen by considering \(\displaystyle \phi \)as a solution of the differential equation, give at least one interval \(\displaystyle I\) of definition.
