MHB Domain & Range: Find It on a Graph
To find the domain and range of a graph, start by considering all real numbers as potential values. Analyze the graph to identify any restrictions, such as vertical asymptotes or holes, which indicate values that cannot be included in the domain. For the range, observe the highest and lowest points on the graph, noting any horizontal asymptotes or limits. A specific example can clarify this process, such as determining the domain and range of a quadratic function, which typically includes all real numbers for the domain and a specific interval for the range based on the vertex. Understanding these concepts is essential for accurately interpreting graphs in mathematics.
teejay
How do you find the domain and range of a graph?
Mathematics news on Phys.org
A specific example, attached to your best efforts, is probably the best way to proceed.
In general, a good place to start is to assume All Real Numbers and see what you can rule out.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
