Undergrad Don't Ever Mention "Centrifugal Force" to Physicists
The discussion revolves around the term "centrifugal force," which many physicists advise against using due to its potential for misunderstanding in non-inertial frames. While some participants find humor in the term's controversial nature, they acknowledge that it can be useful in certain contexts, particularly for beginners. The conversation highlights the importance of clarity in physics terminology, emphasizing that inertial forces should not be confused with real forces. Additionally, there is debate over the naming conventions for devices like pumps and compressors, with suggestions for more accurate terminology. Ultimately, the consensus is that while "centrifugal force" may have utility, it is often misapplied, and proper education on the topic is crucial.
  • #61
Argonaut said:
I've just come across the following line while studying (Young & Freedman) and found it amusing.
It sounds like a dirty family secret we discuss once and then should never mention again :biggrin:
:biggrin: I very well remember that a prof told me the same. "This is not a force!"
Well, to be honest: If it feels phyisically like a force and I could measure it as a force it is force - for me.
  • #62
You can't - that's kind of the point. You can measure things that (in a rotating frame) you might call a reaction to a centrifugal force, but you cannot measure the centrifugal force itself.
Likes vanhees71, Dale and topsquark
  • #63
It doesn't. When analyzing from a rotating frame, the inertial centrifugal force applies to everything that is not on the frame rotation axis. Even to things that are perfectly inertial and definitely don't "feel" any force. It's just there to make the accelerations in the rotating frame consistent with Newtons 2nd Law, not to explain any deformation or stresses.
Likes vanhees71, Dale and Ibix
  • #64
As others have said, you cannot feel or measure an inertial force like the centrifugal force. All that you can do is to infer it through the motion of the object wrt some frame given all of the directly measurable real forces.
For example, in a rotating reference frame you do not measure the centrifugal force on a co-rotating object. You measure the real centripetal force, and then because the object is not accelerating you infer that there must exist a centrifugal “inertial” force which balances the real centripetal force.
Likes vanhees71 and Ibix
  • #65
I am speaking about local measurements in spacetime. Is it just wording?
Say, you have a cylinder with a quite huge radius, rotating. You are inside and grown up inside and you can't see the other side, no curvature, nothing. You jump and you fall back. You call it, whyever, centrifugal force. In other topologies you may have called it gravitation, which I can measure, but in this world I call it "centrifugal force".
What is so wrong about this picture?
Likes sophiecentaur
  • #66
But that is a mistake. A careful analysis will show that you are moving inertially while not in contact with the cylinder - you move in a straight line.
Well, gravity is another thing you can't measure. You can measure the force from the floor on your feet (that's what a weighing scale does), but when you are in free fall there is no detectable force. That's a key insight (the equivalence principle) on the road to general relativity.
(Actually in a true gravitational field you will see tidal effects that are measurable, which you won't in free fall inside a spinning cylinder.)
Likes nasu, Dale and Omega0
  • #67
Omega0 said:
Is it just wording?
It is not just wording. It is a matter of experiment. There is no physical experiment you can make to actually measure an inertial force. You can only infer it from the acceleration combined with measurements of all of the real forces.
I.e. you infer the force from your motion.
You cannot measure it in any other way. It does not produce a reading on an accelerometer or a strain gauge or anything else you can think of. While you are only under the influence of that force all local experiments will be the same as in free fall far from gravity.
Likes Omega0 and nasu
  • #68
Just to expand on that, you can infer from the changing relative motion between you and the floor that there's a force on at least one of you and the floor. And accelerometers attached to the floor will read non-zero while those attached to you read zero. Conclusion: there's a force on the floor and it's accelerating, you are inertial.
The centrifugal force (and other inertial forces) are essentially the terms you have to take from one side of ##F=ma## to the other so that you can say that the floor is not accelerating. That's certainly a useful perspective, but you choosing to juggle terms in the maths doesn't make your sensors behave differently - so centrifugal force is not a thing you can measure.
Likes Omega0 and Dale
  • #69
Oh, okay, shame on me. 😊 I really thought that something which is actually called a force could be called a force. I know the laws from mechanics, we have
$$ \vec{F}_z = -m \vec{\omega} \times (\vec{\omega} \times \vec{r})$$
and that this has for example the name "centrifugal force". I mean, it is obvious that you can cancel the "thing" as an observer outside via a simple transformation. A "real force" is one you will get never get rid off, for example in a free falling system in a gravitational field. If you can't find a transformation from your IS to get rid of the "forces" like unusual displacements, they are forces, correct?
  • #70
Ahhhh I got it, sorry. Absolutely right. Thanks. Maybe I watched too many movies where I thought afterwards that rotation is a nice alternative to gravitation but it is not. So clear. My fault.
  • #71
As I tried to say before in this thread, in the mathematical derivation of the inertial forces in rotating reference frames (rotating against the class of inertial frames to be clear), the inertial forces belong to the left-hand side of Newton's equation ##m \vec{a}=\vec{F}##, i.e., from expressing the components of ##\vec{a}## with respect to the rotating basis in terms of the corresponding position-vector components and its time derivatives:
$$\vec{a}' = \mathrm{D}_t^2 \vec{x}' = \ddot{\vec{x}}' + 2 \vec{\omega}' \times \dot{\vec{x}} + \vec{\omega}' \times (\vec{\omega}' \times \vec{x}') + \dot{\vec{\omega}}' \times \dot{\vec{x}}'.$$
Here ##\vec{x}'## etc. are the components of vectors wrt. the rotating basis, and dots denots usual time derivatives, while ##\mathrm{D}_t## is the "covariant time derivative",
$$\mathrm{D}_t \vec{V}'=\dot{\vec{V}}' + \vec{\omega}' \times \vec{V}',$$
and ##\vec{\omega}'## are the components with respect to the rotating basis of the momentary angular velocity of the rotating basis wrt. an arbitrary inertial basis.
Likes Omega0, dextercioby and Ibix
  • #72
Actually, locally the centrifugal force is a nice alternative to the force of gravity. Einstein’s equivalence principle, his happiest thought, is that locally gravity is equivalent to an inertial force. It is only over sufficiently large distances and times that the differences between gravity and inertial forces becomes apparent.
Likes Argonaut, hutchphd and vanhees71
  • #73
Ibix said:
While we're at it, let's swap the sign on the electron charge so electron flow matches conventional current!
To late. That has been done. More than once.
I'm so old that I have seen electricity go three ways.
In high school I was taught that electricity flowed from positive to negative.
Later in trade school, I was taught that electricity was a movement of electrons which moved from negative to positive.
Some years later I went back to trade school as an instructor and electricity was now again flowing from positive to negative.
I heard speculation that too many text books would have to be rewritten if electricity was allowed to remain flowing from negative to positive.
  • #74
Electric current has always been the flow of positive charge. As it happens. in most conductors we deal with, the charge carriers are negatively charged electrons.
Your instructors may have thought they were helping you but all they succeeded in doing was clearly to confuse you.
  • #75
It always bugs me when teachers in introductory EM classes focus on the movement of electrons or use the term “conventional current”. It is a complete waste of time and effort for both teachers and students.
Likes hutchphd, sophiecentaur and anorlunda
  • #76
I got my introduction to Physics before 'new teaching' came along. At a good middle of the road school, I was told that 'Electric Current' goes from + to - and, when we asked about electrons, we were told 'just wait'. A bit later it all made sense and there were no contradictions or confusions.
  • #77
Exactly, it is better to postpone that topic until the foundation is ready. Electrons don’t need to be discussed in introductory circuits or EM classes*. They are needed in chemistry, solid state physics, and quantum mechanics.
* The only major exception is the Hall effect, but that usually isn’t covered at all or is covered relatively late.
Likes sophiecentaur
  • #78
Even in the case of Hall effect, the charge carriers can be positive or negative in semiconductors.
  • #79
I believe there are aspects of tubes that made it more important to identify the carriers than it does now. Cathode rays no longer abound ion our living rooms !
Likes Dale and sophiecentaur
  • #80
Yes, which is another reason not to fixate on electrons too early. There are currents of positive charge carriers
Likes sophiecentaur
  • #81
And the same is true of the dreaded photons..
  • #82
hutchphd said:
tubes
What are these "tubes" of which you speak? :smile:
  • #83
Small particle accelerators purportedly used by ancient civilizations in their communications devices. (Evidence for Alien intervention in early technology)
  • #84
What about conductors? The idea that they contain charges free to move about in response to external electric fields is essential in understanding electrostatics and Lenz's law. Of course we can pretend that these charges are positive but then a smart student would note that only nuclei contain positive charges and they are certainly not free to move. You can't win this battle.
  • #85
Preposterous! Next you'll be telling me that in case of suspected failure they had then checked out at a pharmacy!
  • #86
It's a matter of learning to crawl before you walk. It is very possible to learn a lot of useful things about circuits and circuit analysis without acknowledging fields or charges.
The assumptions in circuit analysis include "no fields outside of conductors" and "no accumulation of charges at nodes". Things like inductors and capacitors are just components with specific behaviors; it's not necessary to learn about their physics in the first course.
Electrostatics and dynamics and fields can come in a later course.
Since Maxwell's equations require more math, it also makes sense to save the second course until the prerequisite math is taught.
  • #87
A conductor is defined by Ohm’s law. No need to discuss electrons. Particularly since not all conductors have mobile electrons.
I absolutely can win. I would tell the students at the beginning that they should forget about electrons until they are ready for quantum mechanics. Any student asking about electrons would then be given an assignment on what electrons actually are in QED. After they completed that they would be allowed to ask about electrons during office hours.
  • #88
Given Ohm's law, how would you explain charging by induction?
  • #89
I wouldn’t. I would use Faraday’s law instead.
  • #90
Sorry, I meant this kind of charging by induction.
Sorry,
  • · Replies 23 ·
  • · Replies 41 ·
  • · Replies 32 ·
  • · Replies 71 ·
  • · Replies 25 ·
