Doppler Effect Homework: Find Speed of Ambulance
To find the speed of the ambulance, the apparent frequencies of 480 Hz when approaching and 420 Hz when receding are used with the Doppler effect equations. The observer's frequency equations are f' = (vf)/(v - vs) for approaching and f' = (vf)/(v + vs) for receding. The user initially struggled to determine the actual frequency emitted by the ambulance, attempting to use an average value of 450 Hz, which was incorrect. After some algebraic manipulation and guidance from others, the user successfully solved the problem. The discussion emphasizes the importance of correctly applying the Doppler effect formulas to find the speed of a moving source.
asdf12321asdf
A stationary observer at a crosswalk hears an ambulance siren with an apparent frequency of
480 Hz when the ambulance is approaching. After the ambulance passes the apparent frequency is only 420 Hz. Find the speed of the ambulance. Assume v = 343 m/s for the speed of sound in air.
source moving towards observer: f' = (vf)/(v - vs)
source moving away from observer: f' = (vf)/(v + vs)
I am having trouble because I am not sure how to figure out what the frequency of the sound given off by the ambulance is. I tried using 450 since it is halfway between, and it gave me a close answer, but not the correct one. Any help would be much appreciated.
Thanks a lot
hi asdf12321asdf! :smile:
Quelle surprise! :smile:
c'mon … use some algebra! :wink:
oh ok I figured it out thanks a lot
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
