Doppler Effect: Moving Observer riding on moving source With reflection off wall
A bus moving at 37.00 m/s emits sound with a wavelength of 0.1500 m, and the discussion revolves around calculating the frequency of the sound reflected off a wall as heard by an observer on the bus. The initial calculations yield two different frequencies: 2533 Hz and 2839.65 Hz, with the latter being confirmed as correct. The confusion arises from the assumption that the frequency of the source remains constant upon reflection, leading to a discussion about the principles of the Doppler effect. Participants clarify that the frequency and velocity of sound do not change upon reflection, which helps resolve the misunderstanding. Ultimately, the correct frequency observed by the moving observer is established.
ReMa
A bus is moving at 37.00m/s towards a wall. The sound from the bus has an original wavelength of 0.1500m. The sound from the bus reflects off the wall. What frequency sound does an observer on the moving bus hear from the reflection??
Moving Observer: fo = fs (1 + vo/v)
v = LaTeX Code: \\lambda f
Is this doppler effect??
vo = 37.00m/s
Since v = LaTeX Code: \\lambda f
vi = LaTeX Code: \\lambda fi
f = v / LaTeX Code: \\lambda
= (343m/s)(0.1500) = 2286.667hz
Subbing into equation:
fo = (2286.667hz)(1 + 37m/s / 343m/s) = 2533hz
Ok, I ALSO tried another method...
Vs = 37 m/s
Therefore the speed of the wavefront is: vs + v
where v = 343m/s (speed of sound in air)
fs = 343m/s / 0.15m = 2286.667hz
Frequency observed is thus:
(v+vs/v-vs)fs = (343+37 / 343-37) (2286.667) = 2839.65hz
Both of these answers are choices in the multiple choice part, so this is becoming a frustrating question for me.
Help appreciated! Thanks!
The frequency of source does not change on reflection. Could you explain the thought behind your assumption in the first part?
I was confused about that too, but am now thinking I misread some of my notes... which would explain A LOT of why that didn't make sense to me.
Could you check my two possible solutions and let me know if either is correct?
Well the second one is right.
I was thinking if frequency and velocity of propogation of sound do not change in reflection wavelength shouldn't change too.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
