Double Integrals Advice - Please
  • Thread starter Thread starter Nima
    Integrals
The discussion revolves around evaluating the volume generated by the area bounded by the curves y = x^3 and y = x^(1/3) with the function z = x^2y. Participants clarify the correct ranges for the variables, confirming that x should be between 0 and 1, and y should be between x^3 and x^(1/3). There is confusion regarding the lower boundary and the method of generating the volume, with emphasis on understanding the area in the x-y plane and how it relates to the function z. The final consensus is that the volume is formed by projecting the area in 3-D up to the function z(x, y). This discussion highlights the importance of accurately defining boundaries and understanding the volume of revolution concepts in double integrals.
Nima
Hi, I have a question and it asks me to evaluate the volume generated by the area bounded by y = x^3 and y = x^(1/3) and the function z = x^2.y
I'm just having a few problems with setting up the ranges of my variables x and y. I drew a sketch of the area in the x-y plane but I'm not sure what my ranges should be. My guess is: 0 <= x <= 1 and 0 <= y <= [x^(1/3) - x^3].
Help appreciated.
Mathematics news on Phys.org
As far as the xy-plane is concerned, yes, you can take 0< x< 1 and
x3< y< x1/3.
But I am concerned about the lower boundary. Apparently z= x2y is an upper boundary. What is the lower boundary?
x3[/sub]< y< x1/3.
Sorry, there seems to be confusion here, on my part at least.
1.) Your variable ranges are different to mine. Why is mine wrong, and why is yours right?
2.) What are you talking about, lower boundary? We have an area on the x-y plane and we revolve this to the function z = x^2.y to form a volume. Double Integral (x^2.y) dxdy using our variable ranges will evaluate this volume.
Look at your graph. for each point in the area, y is between the two curves: y is between x3 and x1/3. NOT between 0 and x1/3- x3.
You said in your first post that you wanted to find the volume of the region generated but didn't say HOW it was generated. I don't understand what you mean by "revolve this to the function z = x^2.y "
Is this a volume of revolution? If so, what axis are you revolving around?
Thanks, I now understand why my range for y was wrong and yours is right. :)
Sorry, my unclear wording - You have an area in the x-y plane and the volume is generated as: area * height, where height = z(x, y). :. this area is projected in 3-D up to the function z(x, y) to form a volume under z(x, y) with the given x-y plane area as its base.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
