Double Slit Diffraction Problem
The discussion focuses on solving a double slit diffraction problem encountered in an exam. The original poster attempted to find the first maximum's position using Pythagorean theorem and arctan calculations but struggled with the correct approach. Key insights emphasize that constructive interference occurs when the path difference between light rays is a whole number of wavelengths, defining the central maximum as the zeroth maximum. The conversation also highlights the importance of understanding the relationship between the distance from the slits to the screen and the path differences for maxima. Ultimately, the correct method involves applying the appropriate formulas for path differences in diffraction scenarios.
spitonem
I had this problem on my exam and I was pretty sure i knew what to do but it couldn't come up with the right answers.
I diagrammed the problem and showed the way i tried to solve it in blue. Can someone tell me where i went wrong?
Basically i found the length the of the first maximum off the center. i used Pythagorean's theorem to find D2. Then subtracted the two distances to find the difference. I then took the arctan of that distance divided by D1.
Science news on Phys.org
You way over-thought the problem.
Start from the physics: what is the condition that makes a maximum?
the center of a maximum is complete constructive interference from two rays of light?
... good - so what is the condition for constructive interference in terms of the path lengths?
wouldn't it be the wavelength plus by any integer being multiplied by the wavelength?
Almost: the path difference has to be a whole number of wavelengths for constructive interference.
This makes the central maximum the zeroth maximum ... with the 1st and second etc on either side of it.
Lets say D is the perpendicular distance from the slits to the screen - as it is in your diagram.
If D>>d, the path difference between the zeroth maximum and the nth maximum is ##D_n-D=d\sin\theta_n##
You've seen a formula like that before.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
Thread 'How to model converging illumination through object plane (in ZEMAX)'
Hello community, I'm designing a projection lens system for a 35mm film projector in Zemax OpticStudio and struggling with the correct sequential mode setup for the illumination geometry. The light source is a Xenon short-arc lamp reflected by an ellipsoid mirror, which creates a converging cone with a 40.6 degree full angle that passes through the film gate. The film gate is my object plane, but the light doesn't diverge from it like a typical Lambertian source. Instead, the converging...
