Nocturnial
- 1
- TL;DR Summary
- Would you still see an interference pattern if electrons were put through a Stern-Gerlach device after the double slit?
A bit of background: I've read Derive the probability of spin at arbitrary angle is cos( ) | Physics Forums post in this forum and went into a "thought rabbit hole". It didn't make any sense to me and I think I made a wrong assumption somewhere along the way. Instead of typing everything out, I thought it would be helpful to split my assumptions in several different posts.
In a double slit experiment with electrons you'll see an interference pattern (with enough electrons fired). Suppose after the double slit you put a Stern-Gerlach type experiment. Would you still see an interference pattern, but it separated into two rows depending on the spin or is the interference pattern lost?
