Double Slit Experiment: Q&A on Photon Detection
mitarbre
I have a simple question about the double slit experiment for which I couldn't find an answer elsewhere.
Lets say that I shoot one million photons from the source while keeping only the first slit open and that I detect N1 photons on the screen behind the slits. If I now shoot one million photons while keeping only the second slit open I detect N2 photons (N1 and N2 should be pretty close). If I now open both slits and I shoot one million photons how many photons should I detect? N1+N2 or considerably less?
Thanks!
Anyone? Is my question stupid or no one knows the answer?
It should be n1 + n2. Why do you think it should be less.
I wanted to confirm what I thought and if such is the case than it looks to me that the interference pattern is a property of space between slits and the detector and not a property of the particle. In other words, making slits alters the space in such a way that the detected position of the particle is biased. Somewhat like a wavy bowling lane. Does it make any sense?
No, in both cases you detect N1+N2, but that is if you have one HUGE detector that will grab anything past the slits, or alternatively a large number of detectors that cover all space past the slits. The interference pattern has to do with the distribution of photons caught by each such detector, depending on its position, not the total number of photons caught by all detectors
We often see discussions about what QM and QFT mean, but hardly anything on just how fundamental they are to much of physics. To rectify that, see the following; https://www.cambridge.org/engage/api-gateway/coe/assets/orp/resource/item/66a6a6005101a2ffa86cdd48/original/a-derivation-of-maxwell-s-equations-from-first-principles.pdf 'Somewhat magically, if one then applies local gauge invariance to the Dirac Lagrangian, a field appears, and from this field it is possible to derive Maxwell’s...
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
