Double Slit Experiment With White Light
The discussion centers on the appearance of the fringe pattern when white light passes through a double slit. Richard inquires whether the pattern would resemble a single beam that dims away from the center or if distinct fringes would still be visible due to the multiple frequencies of light. Responses indicate that while white light creates a central bright maximum, the varying wavelengths lead to overlapping fringes, resulting in a less defined pattern compared to monochromatic light like blue. The conversation also includes links to resources for further understanding of the double slit experiment. Overall, the effect of white light leads to a more complex and less distinct fringe pattern than that produced by a single frequency of light.
richardstan
Hi,
I have a physics assignment which is asking me what the fringe pattern would look like if white light was passed through a double slit. Would it look like a single light which became gradually darker the further away it got from the central maximum?
Thanks in advance
Richard.
I do not know what level of Physics you are working at. I have a wikipedia link which I will post below and a youtube video which might help. With the wikipedia extract, you might not need to read the whole thing but just pick out the bits that apply to your work, like I doubt you would need to know about Quantum versions of the experiment.
http://en.wikipedia.org/wiki/Double-slit_experiment"
http://www.youtube.com/watch?v=DfPeprQ7oGc"
Hope this helped you.
_Mayday_
Hi, i don't think i gave enough information in my question.
What would the fringe separation look like for white light (multiple frequencies) compared for example to blue light (one frequency). Would it look like a single beam which was bright in the middle and less bright as you went away from the middle, or would there still be several fringes which were less apparent because of all the different frequencies of light constructing in different places?
Thanks in Advance
Richard.
Hope this explains everything
http://www.itp.uni-hannover.de/~zawischa/ITP/bildchen/spalt03.png
Yes it does . Thanks!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
