B Doubt on an EM problem regarding gauss law
The discussion centers on a problem from Griffith's "Introduction to Electrodynamics" involving two overlapping charged spheres. While the initial solution indicates that the electric field in the overlap region is constant, a participant questions why the field isn't zero, given that a Gaussian surface within this region encloses no net charge. It is clarified that a zero net charge does not imply a zero electric field, as demonstrated by the example of a point charge outside a Gaussian surface. The importance of considering symmetries when applying Gauss's law is emphasized, highlighting that the field can be non-zero even when the enclosed charge is zero. The conversation concludes with an acknowledgment of the insights gained regarding the application of Gauss's law.
ubergewehr273
There's this problem 2.18 in the book "Introduction to electrodynamics" by Griffith.
The problem says the following,
"Two spheres, each of radius R and carrying uniform charge densities ##+\rho## and ##-\rho##, respectively, are placed so that they partially overlap (Image_01). Call the vector from the positive center to the negative center d. Show that the field in the region of overlap is constant, and find its value."
Well, I was able to solve the problem as expected from the book, however, I wondered why the field in the region of overlap has to be a non-zero quantity. I could very well take a spherical Gaussian surface that resides inside the region of overlap, and since the net charge enclosed in this region is 0, hence the electric field ought to be zero (refer Image_02). Where am I going wrong over here?
PFA the corresponding images.
##\int \mathbf E \cdot d \mathbf a## is a surface integral. You can "take outside" the absolute value of E only under particular condition of symmetries (pay attention to the dot product between ## \mathbf E## and the surface element ##d \mathbf a##). For example, in spherical coordinates the field inside the surface has to be radial. Here it is most certainly not radial: it is constant! It is explained in the book that you have to pay attention to symmetries when using gauss law.
##\int \mathbf E \cdot d \mathbf a = 0## does not necessarily imply ##\mathbf E = 0##. Take for example a point charge and apply gauss law to a surface that does NOT contain the charge. According to you reasoning you would be tempted to say that the field inside the surface is zero while it is obviously not zero.
Likes ubergewehr273 and PeroK
dRic2 said:
∫E⋅da=0\int \mathbf E \cdot d \mathbf a = 0 does not necessarily imply E=0\mathbf E = 0. Take for example a point charge and apply gauss law to a surface that does NOT contain the charge. According to you reasoning you would be tempted to say that the field inside the surface is zero while it is obviously not zero.
Thanks for the insight :)
Likes dRic2
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Does Poisson's equation hold due to vector potential cancellation?'
Imagine that two charged particles, with charge ##+q##, start at the origin and then move apart symmetrically on the ##+y## and ##-y## axes due to their electrostatic repulsion. The ##y##-component of the retarded Liénard-Wiechert vector potential at a point along the ##x##-axis due to the two charges is $$ \begin{eqnarray*} A_y&=&\frac{q\,[\dot{y}]_{\mathrm{ret}}}{4\pi\varepsilon_0 c^2[(x^2+y^2)^{1/2}+y\dot{y}/c]_{\mathrm{ret}}}\tag{1}\\...
