MHB Draw Sketch: Right Triangle Area = Half Parallelogram Area (Party)
The discussion revolves around the relationship between the areas of right triangles and a parallelogram. It is established that two identical right triangles at either end of the parallelogram can collectively occupy half the area of the parallelogram. Participants clarify that for the triangles to represent exactly half the area, there should be no additional sections between them, implying a direct vertical connection from one vertex to another. The conversation includes visual representations to illustrate the geometric configurations being discussed. Ultimately, the consensus is that the right triangles can indeed represent half the area of the parallelogram under specific conditions.
mathlearn
Any thoughts on the sketch? (Party)
Many Thanks :)
Mathematics news on Phys.org
I presume that the "right triangle" referred to is the one at the right of the parallelogram. It should be clear to you that the right triangle at the left is identical to the first one and has the same area. So in order that the area of either of those two right triangles be "exactly half" the area of the parallelogram, there must be nothing but those two right triangles. That is, there is no "middle section"- the "two" verticals must be one- that vertical goes from vertex D to vertex B. What does that look like?
(Wave) Hello HallsofIvy,
This should be that identical right angled triangle at the left
Then the triangle which has half the area of the parallelogram would be,
Correct ? (Happy)
Many THanks (Party)
Correct ? (Happy)
Hey mathlearn! (Smile)
I think the right triangle is fixed.
We have something like this:
\begin{tikzpicture}[shorten >=1pt, shorten <=1pt, font=\large]
%preamble \usetikzlibrary{arrows}
\def\x{6};
\draw[ultra thick, blue]
(0,0) coordinate (A)
-- ({2*\x - 4},0) coordinate (B)
-- ({2*\x - 4 + \x - 4},{abs(\x - 4)}) coordinate (C)
-- ({\x - 4},{abs(\x - 4)}) coordinate (D)
-- cycle;
\node
at (A) {A};
\node
at (B) {B};
\node
at (C) {C};
\node
at (D) {D};
\draw[dashed] ({2*\x - 4},0) -- ({2*\x - 4},{abs(\x - 4)}) coordinate (E);
\node[above,yshift=3mm] at (E) {E};
\draw ({2*\x - 4},{abs(\x - 4)}) rectangle ({2*\x - 4 + 0.2},{abs(\x - 4) - 0.2});
\draw ({2*\x - 4 - 0.2},{abs(\x - 4)/2 + 0.05}) -- ({2*\x - 4 + 0.2},{abs(\x - 4)/2 + 0.05});
\draw ({2*\x - 4 - 0.2},{abs(\x - 4)/2 - 0.05}) -- ({2*\x - 4 + 0.2},{abs(\x - 4)/2 - 0.05});
\draw ({\x*5/2 - 6 - 0.05},{abs(\x - 4) + 0.2}) -- ({\x*5/2 - 6 - 0.05},{abs(\x - 4) - 0.2});
\draw ({\x*5/2 - 6 + 0.05},{abs(\x - 4) + 0.2}) -- ({\x*5/2 - 6 + 0.05},{abs(\x - 4) - 0.2});
\draw[triangle 45-triangle 45] ({\x - 4},{abs(\x - 4) + 0.25}) -- node[above] {$x$} (({2*\x - 4},{abs(\x - 4) + 0.25});
\draw[triangle 45-triangle 45] (({2*\x - 4},{abs(\x - 4) + 0.25}) -- node[above] {$x-4$} ({2*\x - 4 + \x - 4},{abs(\x - 4) + 0.25});
\end{tikzpicture}
And if we make $x$ smaller, we get:
\def\x{5};
-- cycle;
\node
at (A) {A};
\node
at (B) {B};
\node
at (C) {C};
\node
at (D) {D};
\node[above,yshift=6mm] at (E) {E};
\end{tikzpicture}
Hmm... let's make $x$ negative:
\def\x{-2};
\draw[ultra thick, red]
-- cycle;
\node
at (A) {A};
\node
at (B) {B};
\node
at (C) {C};
\node
at (D) {D};
\end{tikzpicture}
I think we need $x=0$:
\def\x{0};
-- cycle;
\node
at (A) {A};
\node
at (B) {B};
\node
at (C) {C};
\node
at (D) {D};
\draw ({2*\x - 4},{abs(\x - 4)}) rectangle ({2*\x - 4 - 0.2},{abs(\x - 4) - 0.2});
\draw[triangle 45-triangle 45] ({\x - 4},{abs(\x - 4) + 0.25}) -- node[above,xshift=3mm] {$x$} (({2*\x - 4},{abs(\x - 4) + 0.25});
\end{tikzpicture}
Now the right triangle takes up half of the parallellogram. (Happy)​
Correct ? (Happy)
Many THanks (Party)
No, those are not right triangles. And it is always true that the two triangles you get by drawing a diagonal have area half the parallelogram.
- - - Updated - - -
\def\x{6};
-- cycle;
\node
at (A) {A};
\node
at (B) {B};
\node
at (C) {C};
\node
at (D) {D};
\end{tikzpicture}
\def\x{5};
-- cycle;
\node
at (A) {A};
\node
at (B) {B};
\node
at (C) {C};
\node
at (D) {D};
\end{tikzpicture}
\def\x{-2};
-- cycle;
\node
at (A) {A};
\node
at (B) {B};
\node
at (C) {C};
\node
at (D) {D};
\end{tikzpicture}
\def\x{0};
-- cycle;
\node
at (A) {A};
\node
at (B) {B};
\node
at (C) {C};
\node
at (D) {D};
\end{tikzpicture}
Yes, that was what I meant. Nice drawings!​
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
