MHB Drawing Complex Numbers on a Plane
The discussion focuses on plotting complex numbers on a plane, specifically the calculations for four complex numbers: z1, z2, z3, and z4. The first number, z1, is calculated as -i + 1 after rationalizing the denominator. The second number, z2, is the negative conjugate of z1, while z3 is the conjugate of z2. The fourth number, z4, involves dividing z3 by i. The participants clarify the calculations and seek to understand the resulting shapes formed by these complex numbers.
Yankel
Hello all,
I wish to plot and following complex numbers on a plane, and to find out which shape will be created. I find it hard to figure out the first one, I believe that the others will follow more easily (the forth is also tricky).
\[z_{1}=\frac{2}{i-1}\]
\[z_{2}=-\bar{z_{1}}\]
\[z_{3}=\bar{z_{2}}\]
\[z_{4}=\frac{z_{3}}{i}\]
Thank you !
Mathematics news on Phys.org
"Rationalize the denominator": [math]\frac{2}{i- 1}= \frac{2}{i- 1}\frac{-i- 1}{-i- 1}= \frac{2(-i- 1)}{(-1)^2+ 1}= \frac{-2i- 2}{2}= -i+ 1[/math]
you mean -1-i ?
thanks !
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
