Dropping two magnets through a copper tube
Dropping two bar magnets through a copper tube with the same poles facing each other may result in a slight increase in falling speed compared to a single magnet due to decreased magnetic field density between them. The repulsion causes the lower magnet to fall faster while the upper magnet slows down as they accelerate away from each other. Initial experiments showed minimal effects, attributed to an unreliable setup. The influence of eddy currents is expected to be small since the field lines are primarily parallel to the direction of movement. Further experimentation is planned to clarify these effects.
Xiao10
Hi,
In class we were discussing the effects of a two bar magnets being dropped through a copper tube at around the same time, with the same pole facing towards each other, so that the two magnets repel - would the magnets fall through the tube faster or slower than if only one was dropped through?
At a guess I think the magnets will fall slightly faster, the field density between the two magnets should be decreased as the lines are pointing in opposite directions, this means that flux is cut at a lesser rate so the strength of the eddy currents should be decreased.
(The experiment was attempted once, and the effect was seen to be small, however it was quite a unreliable set-up).
I think the lower one would fall quicker, the upper one would fall slower, as both are repelling and therefore accelerating away from each other ;).
Considering eddy currents: I don't know the relative sizes of your setup parts. However, the field lines are mainly parallel to the direction of movement, right? In that case, I wouldn't expect a large effect from eddy currents.
Thanks, that makes sense, will try the experiment again if time and equipment allowsl
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
