MHB Dstermine the equation of function
  • Thread starter Thread starter Azurin
    Function
The equation of the axis of symmetry for the quadratic function is x = -1, indicating the vertex form is y = a(x + 1)^2 + k. Using the points (0, 3) and (-3, 9), two equations can be formed to solve for the parameters a and k. The solutions yield two distinct quadratic functions, one with a positive value for a (opening upward) and another with a negative value (opening downward). Both solutions illustrate the nature of parabolas based on the given points and symmetry. The discussion emphasizes the importance of the axis of symmetry in determining the quadratic function's characteristics.
Azurin
The equation of the axis of symmetry of the graph of a quadratic function is x=-1. The graph passes through the points (0,3) and (-3, 9). Determine the equation of the function.
Mathematics news on Phys.org
$y = a(x-h)^2 + k$
you are given $h = -1$
write two equations using the two given (x,y) coordinates and solve the system for $a$ and $k$
Actually, there are two solutions... one with a = A and one with a = -A. This corresponds to one parabola opening upward and another opening downward.
-Dan
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
