E field outside a current carrying wire
The discussion revolves around calculating the electric field outside a resistanceless wire carrying a steady current, specifically in relation to the Poynting vector. It highlights that the solutions manual suggests a radial electric field proportional to 1/r, which raises questions about the underlying assumptions of linear charge density and static scenarios. The conversation touches on the relationship between electric fields, voltage gradients, and current density, while also considering the implications of special relativity, such as length contraction affecting charge density. There is also a query regarding the impact of nonzero resistance on the calculations. The thread concludes with a request for clarification on the relevant passage in different editions of a physics textbook.
conquerer7
One step in one of the problems in my book (involving calculation of the Poynting vector) asks to find the electric field outside a wire. This wire is resistanceless and the current is steady.
Maxwell's.
Stared at it for a while, had no idea how there would possibly be an electric field, solutions manual says the wire creates a radial one proportional to 1/r.
Hmm. This is a strange question. It seems your book is claiming that there is some linear charge density produced by the current, which then that makes a 1/r radial field. However, the linear charge density assumes a static scenario, which you don't have. Really, the way a wire works is that there is some potential across it V=IR, and the field is the gradient of the voltage (or, alternatively, the field is J/resistivity where J is current density).
Would this have anything to do with special relativity? I remember seeing something about length contraction when switching reference frames once, and about how that produced a charge density out of nowhere.
Edit: what if there's a nonzero resistance?
which book? :confused:
5th edition of HRK's Physics, chapter 38, problem 11.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
