B E.P.E. -> ? when 2 masses are attached to a spring
When two masses m and M are attached to a compressed spring and released, the elastic potential energy converts into kinetic energy, affecting both masses. The center of mass remains at rest, while the masses oscillate around it, indicating that momentum is conserved. The system's frequency is determined by the combined mass and spring stiffness, analogous to a capacitor with inductors. The effective total mass can be calculated using the formula for masses in series. Kinetic energy distribution between the masses occurs in inverse proportion to their respective masses.
Codemetry
Two masses m and M are attached to a compressed spring. When the spring decompresses, the masses won't be pushed off the spring. What will happen to the masses and the entire system? By conservation of energy, the elastic potential energy of the spring will convert into kinetic energy, but which mass / entire system will have an increase in K.E.? What will happen to the center of mass?
You should consider not only energy but momentum conservation. The center of mass keeps at rest. The masses oscillate around it.
I think it may be analogous to a capacitor with two inductors connected across it. This system has only one resonance, caused by the combined inductance. So the combined masses will determine the frequency, in combination with the spring stiffness. As the masses act in series, we need to find the effective total mass from 1/Mt = 1/M1 + 1/M2. The kinetic energy is entirely in the motion of the masses and would seem to be shared in inverse proportion to the masses.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
