fog37
- 1,569
- 108
Hello Forum,
When we take a small metal sphere of radius R1 an charge Q1= 1C and a larger metal sphere with R2=20*R1 and charge Q2=-2C. The spheres are initially separated. Being conductors, all the charge resides on the surface of the spheres. Sphere 1 has an electric potential V_1 (relative to infinity) proportional to Q1 and inversely proportional to R1. Same goes for sphere two which has potential V2. The potentials V1 and V2 are different and assume V1>V2.
Later we connected the two spheres via a metal wires. Charge will flow to make the potentials equal everywhere. The two spheres will eventually become, after a transient, a single equipotential conductor with potential V_final (which is different from V1 and V2). The net charge, Q1+Q2= -1 C, will spread on both spheres in a non-uniform way: the negative surface charge density is larger on the smaller sphere.
Now let's consider a charge conductor carrying charge Q_initial=+1C and planet Earth.
Planet Earth can be considered to be a huge spherical conductor of radius 6,371 kilometers that carries a net negative surface charge of about -1 nC/square meter and capacitance ~ 710 microfarad. Earth's surface is 5.1×108km^2 or 510.1 trillion m² which implies that its total negative surface charge is 5.7*10^5 C. Lots of negative charge!
When we ground the charged object, the object and Earth becomes a single equipotential conductor at the same electric potential V_final. Charge will move around and distributes itself. This equipotential conductor will carry a net negative charge since (Q_initial+Q_earth )~ Q_earth. The highest negative surface charge density will be on the "discharged" conductor which does not really get discharged at all. In fact, regardless of the sign and amount of its initial charge, a charged object that is grounded will eventually carry some negative charge and will not become completely discharged. Capacitance is C=Q/V and for Earth it is very small for Earth (only 710 microfarad). But Q_earth (5.7*10^5 C ) is so huge that V=Q/C for Earth does not change much when Earth receives or gives aways a little amount of charge. The final electric potential that the grounded object and Earth have together is very close (the same for all practical purposes) to the initial Earth's potential V_earth=(9*10^9)*(5.7*10^5 C )/(6,371*10^3) (relative to infinity where V is set to zero).
Since it is potential difference is the quantityy that matters, we often set V_earth=0 instead of using a point at infinity...
Are my observations correct?
I hope so, because I would like to pose another question after this...
thanks,
fog37
thanks,
fog37
