Earth referenced bias into floating circuit?
In summary, connecting an Earth referenced bias voltage to the gate/grid/input of a mosfet/tube/opamp that uses a floating power supply will result in hum and confusing results, as there needs to be a return for the bias to work properly. Shenanigans may also occur due to the lack of current paths to charge and discharge the gate capacitance.
coinmaster
41
What happens if I for example, connect an Earth referenced bias voltage to the gate/grid/input of a mosfet/tube/opamp that uses a floating power supply?
Does the bias simply not work or does the circuit somehow become Earth referenced?
I suspect you know the answer to this. There always has to be a return of some kind. It is likely you would introduce a lot of hum. It would not bias in a useable or constructive way.
In the case of FETs you will get some really confusing results. If you happen to luck out and get all of the voltages correct you will not have current paths to charge and discharge the gate capacitance properly. Shenanigans will ensue.
BoB
Related to Earth referenced bias into floating circuit?
1. What is Earth referenced bias into floating circuit?
Earth referenced bias into floating circuit is a phenomenon that occurs when a circuit, which is supposed to be isolated from the Earth ground, becomes influenced by the Earth's reference potential. This can happen due to various factors such as capacitive coupling, stray capacitance, and electromagnetic interference.
2. How does Earth referenced bias affect floating circuits?
Earth referenced bias can cause significant errors in the operation of floating circuits. It can lead to inaccurate measurements, signal distortion, and even circuit malfunction. In high-precision applications, this bias can have a significant impact on the overall performance of the circuit.
3. What are some common techniques to mitigate Earth referenced bias in floating circuits?
There are several techniques that can be used to reduce or eliminate Earth referenced bias in floating circuits. These include using isolation amplifiers, optocouplers, and transformers to isolate the circuit from the Earth ground. Shielding and grounding techniques can also be employed to reduce the effects of external interference.
4. How can one measure the level of Earth referenced bias in a floating circuit?
The level of Earth referenced bias can be measured by using a differential amplifier. This amplifier can measure the potential difference between the floating circuit and the Earth ground. The measured voltage can then be analyzed to determine the level of bias present in the circuit.
5. Can Earth referenced bias be completely eliminated in floating circuits?
While it is not possible to completely eliminate Earth referenced bias, it can be minimized to a great extent by using proper isolation and grounding techniques. In high-precision applications, it is crucial to carefully design the circuit and use high-quality components to reduce the impact of Earth referenced bias.
  • Electrical Engineering
