Earth science, surface energy balance
The discussion focuses on calculating the equivalent loss of stored soil liquid water using the surface energy balance equation Q* = QH + QE + QG, where QH is sensible heat flux, QE is latent heat flux, and QG is ground heat flux. Participants emphasize the need for context, specifically the hourly-averaged energy balance data from a grassland study in Alberta. The goal is to determine the total loss of soil water over a 24-hour period, converting the energy fluxes into millimeters using the density of liquid water. The provided data includes hourly measurements of energy balance components, essential for the calculations. Understanding these terms and the context is crucial for accurately addressing the problem.
suedenation
Given the equation Q* = QH + QE + QG and the corresponding data (all fluxes in [W/m²]). How can I find the equivalent loss of stored soil liquid water expressed in [mm] (Note: the conversion factor is the density of liquid water, i.e. 1000 kg/m^3)
Thanks very much for your help!:confused:
First of all, what do you mean by QH, QE, QG? Can you tell us what the terms mean in your equation?
Also, you need to give the question in it's full context.
i'm sorry, the question is about surface energy balance. Given Q* = QH + QE + QG, QH = sensible heat flux, QE = latent heat flux and QG = ground heat flux. (All fluxes in [W/m²]) and the table below, I've to calculate the 24 hour totals equivalent loss of stored soil liquid water expressed in [mm] (note: the conversion factor is the density of liquid water, i.e. 1000 kg/m^3)
Table 1: Daily cycle in hourly-averaged energy balance components over grassland in Alberta.
1 July 2003. (All fluxes in W m¡2; data courtesy of Dr. L. Flanagan; file flanagan.txt)End time [MDT]
hr Q¤ QG QH QE
1 -77 -17 -117 23
2 -68 -17 -67 11
3 -38 -25 2 -2
4 -37 -29 2 -2
5 -31 -27 -5 -1
6 34 -19 -26 2
7 134 -4 3 72
8 262 13 42 136
9 312 28 60 212
10 438 31 99 272
11 518 45 162 315
12 632 65 213 316
13 633 68 208 339
14 595 61 200 347
15 563 54 167 337
16 347 34 73 278
17 311 28 53 230
18 209 13 -35 139
19 81 1 -52 111
20 -15 -5 -44 55
21 -62 -11 -103 23
22 -63 -14 -106 17
23 -62 -14 -77 12
0 -66 -15 -101 19
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
