Earth’s magnetic field alignment and climate change?
In summary: Aametsoc.org%2Fsearch%3Fq%3D%27energy+balance%27+&oe=UTF-8&btnI=Google+Search&hl=en&btnJ=Search+Results&lr=&start=0&btnG=Search+More&btnF="The Earth's atmosphere does almost all of the heavy lifting in that regard."The Earth's atmosphere does almost all of the heavy lifting in that regard.
BeedS
47
The Earth’s magnetic field is slowly moving with respect to the Earth’s surface and to the Sun’s incoming radiation and solar wind direction. Does the tilting/moving of Earth’s magnetic field axis to the incoming solar wind direction change the protection on different points of the Earth’s surface?
By the Magnetic field alignment moving can it influence climate change at different points on the Earth’s surface?
There's no evidence of a correlation and no reason to think there should be.
Likes jim mcnamara, davenn and Evo
The periods don't even align. In the last 100M years, there has been one ice age and two interglacials - but about 200 reversals.
Ok, so if the magnetic north pole was facing the Sun it would give the same protection as the current alignment does now?
No, but solar wind has nothing to do with global temperatures/warming.
russ_watters said:
No
Do you know of any research done on magnetic field alignment and solar wind direction? I wonder what the bow shock would look like if the magnetic north pole was facing the sun and will the north/south pole funnel the solar wind?
This wiki on solar wind says it's quite hot 80000k
https://en.wikipedia.org/wiki/Solar_wind
Not offhand, but I'm sure some is out there if you look.
Ok... You are aware that we have sent dozens of spacecraft beyond Earth's magnetic field, right? Do they [risk] burn up or freeze?
Um, IIRC, there may be some subtle effects due to UV and cloud-seeding / lightning / sprites etc triggering by radiation.
Given our magnetic poles are currently far, far away from sub-solar zone, the nearest, poor analogue would seem a 'Carrington Event' or equivalent, which have wild aurorae but no apparent climate impact, I got to go with the comment above about lack of correlation between reversals and ice-ages...
Likes russ_watters
BeedS said:
https://www.nasa.gov/sites/default/..._Space_Environment-ISS-Mini-Book-2015-508.pdf
This is for the ISS that's only 400 km away and well within the Earth's magnetic field protection.
That paper is 40 pages long. Can you quote a relevant passage? After a quick skim I don't see any relevance to this discussion.
The solar wind doesn't carry or produce heat and the wiki article is wrong?
The wiki is not wrong; the solar wind carries heat. But it is vanishingly thin, so it carries only a vanishingly small amount of heat. You could probably calculate, from information in the wiki article, how much heat in watts per square meter and compare it to sunlight.
Likes BeedS
hmmm27 said:
and it doesn't actually appear in the article referenced.
"In near-Earth space, the slow solar wind is observed to have a velocity of 300–500 km/s, a temperature of 1.4–1.6×10^6 K and a composition that is a close match to the corona. By contrast, the fast solar wind has a typical velocity of 750 km/s, a temperature of 8×10^5 K and it nearly matches the composition of the Sun's photosphere."
The solar wind is indeed really hot but the density is very very very low. The temperature is not the only parameter important in heat transfer, the number of particles is also an important criteria.
To have an idea of the magnitude of the energy fluxes in the atmosphere, I suggest you these:
https://www.acs.org/content/acs/en/climatescience/energybalance/planetarytemperatures.html
https://journals.ametsoc.org/doi/10.1175/2008BAMS2634.1
(you can get this paper by searching its title on Google)
Likes BeedS
@BeedS, are you arguing that the Earth's magnetic field does affect climate change or are you arguing that it should?
I don't know if Earths magnetic field can affect climate change. I'm trying to find out if there is any known correlation or if there is any possibility that it can contribute through magnetic field dynamics.
This question
has been answered more than once
Thread closed.
Likes BeedS, BillTre, russ_watters and 2 others
Related to Earth’s magnetic field alignment and climate change?
1. What is Earth's magnetic field?
Earth's magnetic field is a protective shield that surrounds our planet and is created by the movement of molten iron in the Earth's outer core. It extends from the interior of the Earth to the magnetosphere, a region in space where the magnetic field interacts with the solar wind.
2. How does Earth's magnetic field affect climate change?
Earth's magnetic field plays a crucial role in protecting our planet from the harmful effects of solar radiation. It deflects charged particles from the Sun, preventing them from reaching the Earth's surface and causing damage to our atmosphere. This protection is important for maintaining a stable climate on Earth.
3. Is there a correlation between Earth's magnetic field alignment and climate change?
There is ongoing research to determine the possible relationship between changes in Earth's magnetic field alignment and climate change. Some studies suggest that changes in the magnetic field may affect the Earth's climate by altering the amount of solar radiation that reaches the Earth's surface. However, more research is needed to fully understand this relationship.
4. Can Earth's magnetic field change over time?
Yes, Earth's magnetic field is constantly changing in both strength and direction. This is due to the movement of the molten iron in the Earth's outer core, which can cause fluctuations in the magnetic field. These changes can occur over long periods of time and can also be influenced by external factors, such as solar activity.
5. How does the Earth's magnetic field protect us from climate change?
The Earth's magnetic field helps to protect us from the effects of climate change by deflecting harmful solar radiation. This radiation can cause damage to the Earth's atmosphere, leading to changes in the climate. Without the protection of the magnetic field, our planet would be much more vulnerable to the effects of climate change.
12K
  • Earth Sciences
  • Astronomy and Astrophysics
  • Quantum Physics
