Earth's Rotation & Global Agriculture: Impact & Possibilities
In summary, the filling of the Three Gorges Dam's impact on the Earth's rotation rate was not detectable.
imotta
How much will this phenomenon affect the Earth's rotation? Is it possible that the change in the Earth's rotation movement will significantly affect agricultural production on a global scale, for example?
Science news on Phys.org
You are suggesting that the migration of fluid from the polar ice cap to the oceans will make the Earth "shorter and fatter", thus slowing its spin rate? And that the resulting change in day length will affect agriculture?
Have you calculated how much change in day length would result from moving the [south] polar ice cap to the equator? Make some generous assumptions and see what you get.
Likes davenn, Vanadium 50, anorlunda and 1 other person
As the Antarctic ice cap melts it will distribute it's mass equally over the oceans. The moment of inertia of the Earth will change as the mass of the ice is redistributed from a disk near the axis to a spherical shell over the oceans.
Conservation of angular momentum will slow the Earth. The day will lengthen by less than a second, but sundials will also slow down to fully compensate.
The main change that people and their economy will have is sea level rise, firstly because of the melt water, and secondly because of the thermal expansion of the water column happening at the same time due to the warming that melts the ice. The coastal regions and many major cities will be drowned long before anyone notices the solar days are very slightly longer. So yes, the Earth will slow, the days will lengthen, but you will certainly not notice it without an atomic clock.
NASA write; “For example, if the Greenland ice sheet were to completely melt and the meltwater were to completely flow into the oceans, then global sea level would rise by about seven meters (23 feet) and the Earth would rotate more slowly, with the length of the day becoming longer than it is today, by about two milliseconds”.
https://climate.nasa.gov/faq/30/if-...an-what-would-happen-to-the-planets-rotation/
Likes Leo Liu and sophiecentaur
I calculated
Was the filling of the Three Gorges Dam's impact on the Earth's rotation rate detectable?
For the polar cap, aproximate ##cos L = 0## and ##m=2.65 \times 10^{19}##, so the fractional change in moment of inertia is
$$\frac{mR^2}{I}( \frac{2}{3})
= \frac{2.65 \times 10^{19} \times(6.37 \times 10^{6})^2}{8.04×10^{37}}(\frac{2}{3}) = 8.9 \times 10^{-6}$$
which is also the fractional decrease in rotation rate.
Likes Leo Liu
FAQ: Earth's Rotation & Global Agriculture: Impact & Possibilities
What is the relationship between Earth's rotation and global agriculture?
Earth's rotation plays a crucial role in global agriculture as it affects the distribution of sunlight and temperature across the planet. This, in turn, impacts the growth and productivity of crops and other agricultural activities.
How does Earth's rotation affect the length of a day?
Earth's rotation determines the length of a day, which is approximately 24 hours. As the Earth rotates on its axis, different parts of the planet are exposed to the sun, causing day and night cycles.
What are the potential impacts of Earth's rotation on global agriculture?
The changing patterns of sunlight and temperature due to Earth's rotation can lead to droughts, floods, and other extreme weather events, which can have significant impacts on crop yields and food production. It can also affect the migration patterns of animals that are essential for pollination and pest control in agriculture.
Can Earth's rotation be influenced by human activities?
While human activities do not directly influence Earth's rotation, they can indirectly impact global agriculture through climate change. The burning of fossil fuels and deforestation can alter the Earth's atmosphere, leading to changes in temperature and weather patterns that can affect agricultural productivity.
Are there any possibilities for utilizing Earth's rotation to improve global agriculture?
One possibility is using precision agriculture techniques that take into account the changing patterns of sunlight and temperature to optimize crop growth. Additionally, understanding the effects of Earth's rotation on climate can help in developing more resilient and sustainable agricultural practices.
