MHB Eb 4.d determine the magnitude and direction of V
The magnitude of vector V is calculated as approximately 11.70 units, using the formula √((-9.8)² + (-6.4)²). The direction initially calculated as 33.15° is corrected to 213.15° by adding 180° since both components are negative, placing it in quadrant III. The discussion also addresses the use of symbols for magnitude and direction, with suggestions for alternatives to arrows on graphs. Additionally, the proper LaTeX command for the degree symbol is noted as ^{\circ}. Overall, the thread emphasizes the importance of correctly determining vector direction based on quadrant placement.
karush
MHB
$\tiny{\\ eb 4.d}$
$\textsf{If $v_x=-9.80$ units and $v_y=-6.40$ units,}\\$
$\textit{determine the magnitude and direction of $V$.}$
\begin{align*}\displaystyle
magnitude&=\sqrt{(-9.8)^2+(-6.4)^2}
=\color{red}{11.7047}\\
direction&=\arctan{\left[\frac{6.4}{-9.8}\right]}
=\color{red}{33.15^o}
\end{align*}
ok the direction is actually in the Q4 but $\arctan{\left[\frac{-6.4}{-9.8}\right]}$
is in Q1! Do we just add $180^o$ for that or is it $-33.15^o$
Also is there symbols for magnitude and direction other than an arrow on the graph
Also where is the latex for degree instead of ^o
Mathematics news on Phys.org
karush said:
$\tiny{\\ eb 4.d}$
\end{align*}
The direction would be in quadrant III, and so recognizing that both components are negative, you would in fact add $\pi$ to the angle:
$$\theta=\pi+\arctan\left(\frac{v_y}{v_x}\right)$$
I use ^{\circ} for the degree symbol.
$\textsf{ok so it}$ $$33.15^\circ + 180^\circ = 213.15^\circ $$
that would place it Q3
actually why don't we have \degree on the Symbol/Command Set:
It was an oversight I suppose, but adding it now would require a lot of effort. :)
I completely understand:cool:
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
