MHB Edgar's Question from Facebook: Convex Polygon
  • Thread starter Thread starter Sudharaka
    Convex Polygon
The problem states that the sum of the interior angles of a convex polygon is ten times the sum of its exterior angles. The formula for the sum of the interior angles of a convex polygon with n sides is S=(n-2)180°. The sum of the exterior angles is always 360°. By setting up the equation (n-2)180°=10*360° and solving, it is determined that n=22. Therefore, a convex polygon with 22 sides satisfies the condition given.
Sudharaka
MHB
Edgar from Facebook writes:
The sum of the measures of the interior angles of a convex polygon is ten times the sum of the measures of its exterior angles. Find the number of sides of a polygon.
Hello could you please help me to solve this problem?
Mathematics news on Phys.org
Hello Edgar,
We need two theorems here:
  • For a convex polygon having $n$ sides, the sum $S$ of the interior angles is given by $S=(n-2)180^{\circ}$.
  • Regardless of the number of sides, the sum of the exterior angles is $360^{\circ}$.
Hence, we need to solve the following for $n$:
$(n-2)180^{\circ}=10\cdot360^{\circ}$
Divide through by $180^{\circ}$:
$(n-2)=10\cdot2$
$n-2=20$
$n=22$
Thus, we have found a convex polygon having 22 sides meets the stated requirement.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
