Effect of time dilation on Earth/space communication?
The discussion centers on the effects of gravitational time dilation and relativistic motion on audio signals transmitted between Earth and a spacecraft. It posits that while gravitational redshift and Doppler effects could theoretically alter the frequency of a 440 Hz audio tone, the shifts are negligible for practical listening purposes. The technology used in audio transmission, such as TCP/IP and UDP protocols, incorporates error detection and correction, ensuring that voice messages remain intelligible despite any frequency shifts. Additionally, while astronauts may perceive slight changes in pitch due to relative motion, these are often overshadowed by other factors like volume loss and static interference. Overall, the impact of these shifts on audio fidelity is minimal, and modern encoding techniques effectively mitigate potential distortions.
InquiringMind
Let's say there is an audio oscillator on earth sending a 440 Hz audio tone over radio to a spacecraft. There is also an audio oscillator on the spacecraft sending a 440 Hz audio tone over radio to earth. Time is slower in the high gravity of earth than the weak gravity in space. Is the 440 Hz signal received by the spacecraft less than 440 Hz and the 440 Hz signal received on earth greater than 440 hz.
If there is a shift in audio frequency, I would think it would change the pitch of an astronaut's voice heard on earth (it would be higher pitched) and the voice of someone on earth would be heard at a lower pitch by an astronaut. Does this happen, or is the shift too small to be noticed?
As you assumed, as for the Earth, red-shift for outgoing and blue-shift for incoming lights take place. The shifts are measurable and well conidered in GPS satellite design for an example. I am not a expert of human listening physiology enough to tell you whether ears can distinguish it or not.
It depends how the audio signal is encoded. The underlying radio signal would be blue/red shifted, but whether this results in the encoded voice message being changed depends on the technology.
The gravitational redshift of the radio signal between Earth and a spacecraft would be negligible.
If the spacecraft was moving at relativistic speed relative to Earth, then there might be a significant red/blue shift in the underlying radio signals. But, the technology could take that into account when decoding a voice message.
Likes Klystron and jbriggs444
Shouldn't be difficult to calculate. I wonder if the Doppler effect won't be more prominent though.
For weak fields, we can factor the predicted effect into components from two primary sources: kinematic (relativistic Doppler) and general relativity (gravitational red/blue shift).
A full computation from General Relativity would combine the two effects in a non-linear way. But for the weak field of the Earth, we can compute the effects separately and simply add them together.
I would expect fore-and-aft relativistic Doppler to dominate for most listening angles. When the space craft is approaching, you get blue shift. When departing, you get red shift.
When the craft is directly overhead in low earth orbit then transverse relativistic doppler yields a red shift. For low earth orbit, this effect dominates over gravitational blue shift. For a sufficiently high orbit it is gravitational blue shift that wins instead.
I recall a fairly recent thread about the crossover altitude where the kinematic and gravitational effects cancel, but I no longer recall the title. For GPS satellites, the net red shift is about 7 microseconds per day. Which is utterly negligible for purposes of listening to a 440 Hz tuning fork.
Likes Klystron, berkeman, Borek and 1 other person
Digitally encoded transmitted messages, including human voice, should not be altered by the processes described in the original post.
Transmission Control Protocol -- Internet Protocol (TCP-IP) packets, for example, contain error detection that improve data integrity regardless of changing signal characteristics assuming reliable connection. The connectionless User Data Protocol (UDP) provides enhanced error detection including checksums suitable to carry Real-Time Transport Protocol (RTP) designed to carry information such as real-time voice/image streams.
Returning to the original 440hz signal deployed as carrier then modulating human voice on or within it, optimum methods suggest comparing amplitude with frequency modulation (AM / FM) techniques in the discussion. Radial relative motion toward and away from an emitter should affect AM receiver fidelity to a greater extent while frequency shifts as described in prior posts will require interesting error correction for FM receivers.
Terrestrial FM radio receivers certainly benefited from automatic frequency control (AFC) circuits that compensate for carrier frequency fade, waver, shifts and related interference. The interesting question of detecting corresponding changes in perceived pitch of a modulated analog voice might be subsumed in the loss of fidelity.
IOW Yes, I have heard changes in pitch of broadcast voice and music due to relative motion and during TX/RX glitches, but attendant loss of volume and static interference compared to perceived pitch renders the question somewhat academic, if not moot. Correcting the signal, including for relative motions of TX and RX, should preclude voice distortion, at least from regular motion.
Thread 'RIP Chen Ning Yang (1922-2025)'
https://en.wikipedia.org/wiki/Yang_Chen-Ning ( photo from http://insti.physics.sunysb.edu/~yang/ ) https://www.nytimes.com/2025/10/18/science/chen-ning-yang-dead.html https://www.bbc.com/news/articles/cdxrzzk02plo https://www.cpr.cuhk.edu.hk/en/press/mourning-professor-yang-chen-ning/ https://www.stonybrook.edu/commcms/physics/about/awards_and_prizes/_nobel_and_breakthrough_prizes/_profiles/yangc https://www.stonybrook.edu/commcms/physics/people/_profiles/yangc...
Thread 'In the early days of electricity, they didn't have wall plugs'
Hello scientists, engineers, etc. I have not had any questions for you recently, so have not participated here. I was scanning some material and ran across these 2 ads. I had posted them at another forum, and I thought you may be interested in them as well. History is fascinating stuff! Some houses may have had plugs, but many homes just screwed the appliance into the light socket overhead. Does anyone know when electric wall plugs were in widespread use? 1906 ad DDTJRAC Even big...
