collinsmark
- 3,442
- 3,373
Baluncore said:Destructive interference will destroy the advantage of an aperture. If it takes 1 second for the modulation clock to spread across the elements of a flat iris, then the data rate will be less than 1 bit per second.
The data rate could be greatly increased by employing a parabolic iris, and distributing the modulation clock to each element from the focus. The modulation bandwidth would then be limited by the phase error of the parabolic iris surface, with receiver noise and bandwidth being a separate problem.
Or different elements of a flat iris could be phase compensated. In other words, a larger delay could be added to iris elements close to the clock source and smaller delays added to iris elements farther away from the clock source. From a far distance, all elements of the iris would appear to change state in-sync.
Such delays would involve a little latency. But again, such things are the least of our worries about such a monstrosity.
