Effects of high voltage & current on a large volume of water
In summary,A surge of high voltage electricity at a gas-insulated switchgear creates a flashover whose Breaker Current Failure Detectors have been deactivated so that the arc is sustained during 37 seconds. The whole installation is secret so it is located underground.There is a steel tank of water close-by whose capacity is 34 million litres buried 65 meters deep into the ground. It is three quarter full. The ground is rock but if the material matters (it probably will) this can be changed in the scenario. (distance between switchgear and tank should be less than a kilometre). The electricity is diverted into the tank.The questions are:How intense should the current be to flash the
Eric Willems
Hi,
For a book that I’m writing, i need to know how to describe the following, if the situation described is ever possible, otherwise I'll have to come up with another scenario.
The questions are:
How intense should the current be to flash the water into steam, burst the tank and produce a mini earthquake on the surface?
Could it also produce a steam geyser that lasts for a couple of minutes?
Corollary effects will collapse houses on the surface and injure a small population due to steam burns.
Thanks a lot for your answers. I apologize in advance if my request is too farfetched. My formation is not physics. I'm just looking for some believable situations.
Eric
Hallo Eric, :welcome:
Heat needed to evaporate water (from 100 C water to 100 C steam) is about 2 kJ/kg. You have 3/4 * 34 = 25 million kg of water so you would need 50000000000000 Joules ( 5 x 1013 ) just to evaporate the water. That's a lot.
A big lightning strike is 10000000000 Joules ( 1010 ) so you'd need the energy of 5000 of them.
Or, to come back to your 37 seconds: per second you need 1.5 x 1012 Joules, i.e. one and a half million volts discharging with one million amperes.
Other terms: one ton of TNT is 4 109 Joules, so you'd need 12 kiloton of the stuff. Half a Fat Man
On the bright side: I personally wouldn't feel cheated at all when such a spectacle evolves on a movie screen.
Likes Eric Willems
Thank you so much BvU for your answer,
I think I'm getting closer to visualize this. But the energy needed is fantastic! Is there any hardware that could withstand this voltage and amperage without frying or vaporizing before the 37 seconds have passed? I mean to continue discharging electricity without failing?
I really appreciate this,
This is of huge help to me.
Regards
Eric
Well, I don't know of a way to store so much energy (except with a truckload of tnt or a nuclear device). On the other hand: why do you think it's necessary to evaporate all the water ? Heating it up until the vapour pressure rips the tank apart (google steam boiler explosion - e.g. here ) creates a hefty bang too (the rest of the water suddenly experiences a lower pressure and flashes (=evaporates), thus gaining tremendously in volume.
But 65 m of Earth isn't easily stirred, I suppose.
Likes Eric Willems
I'm sure you're right. I probably set the parameters out of ignorance. Let's rephrase :
The event take place some 800 years into the future.
The location is a planet orbiting an F9 star.
It's a runaway greenhouse effect world. The only inhabitable areas are the flat tops of a few very high Tepuis (about 40 miles high). (See Landis's proposal about colonizing the clouds of Venus as a basis for the logic behind floating cities in high atmosphere). Those Tepuis are the result of geological stress induced by the flyby of a superdense object early in the formation of the planets in the accretion disk of the star.
Those tepuis are now isolated reservations for intelligent species of the galaxy. A kind of Vault against genocide.
They are controlled and monitored by AIs.
A couple of those AIs battle for control.
All AIs were interconnected at an earlier stage for energy sharing.
The production of energy is geothermal.
At the surface of each Tepui, there is a small settlement of each species whose numbers is artificially maintained low to avoid overpopulation and their technology is artificially maintained at a basic level.
The location of the base is usually underground (depth is not set at a mandatory 65 m, it can be adapted following your advice), directly below or not far from the main settlement on the surface.
In this case, one of the AIs manages to reestablish a high voltage connection with the powergrid of its archenemy.
This last diverts the attack to the main tank.
The Switchgear is gas-insulated. It's ultra-high voltage so it's upwards of 400 KV.
The Breaker Current Failure Detectors have been deactivated.
The flashover will be sustained as long as possible if it is relevant to the result.
The current is diverted into the main water tank directly, not through the intermediary of a resistance.
The effect must provoke a mini earthquake, destroy the tank, a part of the base and a part of the settlement. It must also burst through the surface and provoke a geyser whose high is ...? and duration is ...?
Do I need all the power you described or can it be described in another way with less power?
Thank you again, your advice is invaluable!
Regards
Eric
Nice story, nice setting, but more or less: End of my wits :smile:
I'll try and refer you to someone who kows a bit more about such things, only I don't know who has explosion expertise, so it may go via-via. @Chestermiller: how can we help Eric further here ?
Likes Eric Willems
Thank you very much for your help BvU. Pending.
Eric
Related to Effects of high voltage & current on a large volume of water
1. How does high voltage and current affect the temperature of water?
High voltage and current can significantly increase the temperature of water due to the Joule heating effect. This occurs when the electrical energy is converted into heat energy, causing the water molecules to vibrate and increase in temperature.
2. What are the potential dangers of exposing water to high voltage and current?
Exposing water to high voltage and current can lead to electrocution, as water is a conductive material. It can also cause damage to electrical equipment and potentially start a fire if the water comes into contact with electrical outlets or wiring.
3. Can high voltage and current affect the chemical composition of water?
Yes, high voltage and current can cause electrolysis in water, which can result in the separation of water molecules into hydrogen and oxygen gas. This can also lead to changes in the pH level of the water.
4. What happens when a large volume of water is exposed to high voltage and current?
When a large volume of water is exposed to high voltage and current, the effects can be amplified due to the increased surface area. This can result in a more rapid increase in temperature and potential hazards, such as electrocution or equipment damage.
5. Are there any benefits to using high voltage and current in water treatment processes?
Yes, high voltage and current can be used in water treatment processes to kill bacteria and other microorganisms through a process called electrocoagulation. It can also help with the removal of pollutants and organic compounds from water.
  • Electromagnetism
  • Electrical Engineering
  • DIY Projects
