Efficiently Dropping Voltage: What's the Best Method?
To efficiently drop a 10v Li-ion battery to 6v DC, a switching regulator is recommended due to its high efficiency, typically over 90%, compared to linear regulators which waste power as heat. The LM317 is a common choice for simpler applications, but it may not be the best for minimizing heat loss. For a bike light application, maintaining compactness while maximizing battery run time is crucial. Heat dissipation must be managed effectively, regardless of the chosen method. Ultimately, while DIY solutions are viable, purchasing a pre-made bike light could be a simpler option.
couchsurf
Looking to drop a 10v Li-on battery to 6v DC. What is the most efficient way without to much wasted power. Adjustable voltage regulator? diodes?,
something else? needs to be small. Thanks
What do you mean by most efficient? All of the power of the drop will be lost unless you are willing to do a switching regulator.
The simplest way would be to us an adjustable linear regulator of the appropriate power rating. The LM317 is the jellybean part that is used for this application:
http://www.national.com/pf/LM/LM317.html
You can make a circuit with a power transistor and two resistors, to give you some fairly stable voltage drop, but it varies with temperature a little bit, and is not as stiff as using the LM317. And the two options are about the same in size.
Remember that you need to dissipate that heat somehow, and keep it away from the battery itself. Use appropriate heat sinking or some other option to get rid of the heat.
EDIT -- fixed typo "power resistor and two resistors" -> "power transistor and two resistors" (jeeze)
Switching regulators are not really any more difficult to use than linear regulators. For most applications, switchers are perfect.
- Warren
The application it will be used for is a bike light. 6v 15w bulb, the battery is a 10.8v 3.6 Ah that is doing nothing right now. I figure a burn time of about 2.5 hrs with this if I get it down to 6 volts. Because its on a bike I wanted to keep it small. Also thinking about a digital controller. Efficiency? I didn't want to have the 4 extra volts being turned into heat vs. getting a longer run time from the battery, but I'm not sure what is possible.
I found an old 6volt resistance unit on the fire wall of a junked car. For years I used it to step down twelve volts to six volts for small radios on the sailboat. It worked great!
A well designed switching power supply is typically over 90% efficient. <EDIT: took out sentence here..> Take a look at National's LM5005 regulator datasheet, which includes circuits.
This is a fun project, but if you are looking for an easy approach then buy a bike light!
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
