- #36
DrGreg
- 2,083
The interval "ds2" is invariant -- the same value between a given pair of nearby events according to every observer. If the observer is using standard Einstein-synced Minkowski coords, the interval is always given by the formulaKen G said:Right, so although it's common to state that the Minkowski norm is "coordinate independent", that's only true within a coordinate subclass. What we need to know is, what is the core principle that unites the Minkoswki norm with the radio norm? A mathematician could probably say it in one line, but I wouldn't understand a single word-- I want the physical statement, and I feel that we should teach relativity to reflect that, rather than asserting a constant speed of light as if it were a physical fact (that is very much what is normally done).
[tex]ds^2 = dt^2 - dx^2/c^2 - dy^2/c^2 - dz^2/c^2[/tex]
(the c might be in a different place or the signs might be opposite according to what your metric sign convention is, but once that's decided, all observers use the same formula).
The physical significance of the interval (as I chose to write it) is:
- if ds2 > 0, ds is the proper time taken by an inertial observer to travel between the events (and it is also the longest proper time that anyone, inertial or not, could take to travel between the events) "Proper time" means time measured by your own clock between events that occur at zero distance from yourself (so no sync required).
- if ds2 < 0, [itex]\sqrt{-c^2ds^2}[/itex] is the proper distance between the events measured by an inertial observer who considers them to be Einstein-simultaneous
- if ds2 = 0, it is possible for a photon of light to pass through both events.
If you use coordinates other than the standard orthogonal Einstein-synced coords, you will get a different formula for ds2.
For example, even with Einstein-synced time but spherical polar spatial coords, you get
[tex]ds^2 = dt^2 - dr^2 / c^2 - r^2 ( d\theta^2 + \sin^2 \theta d\phi^2) / c^2 [/tex]
In Special Relativity (SR), you never use coordinates like this, but in General Relativity (GR), you have no choice but to do so. Special Relativists almost always use Einstein-synced orthogonal Minkowski coords, but General Relativists are happy to use any coordinate system you like. (But the maths of GR is a whole lot more complicated than SR.)
On a final note, I believe the second postulate should really be interpreted as "the motion of a photon is independent of whatever emitted it", so that it is impossible for one photon to overtake another traveling in the same direction. The fact that all inertial observers using Einstein-synced clocks agree on the value of the coordinate speed of light is then really a consequence of the first postulate (because otherwise you could distinguish one frame from another). (See "Two myths about special relativity", Ralph Baierlein, http://link.aip.org/link/?AJPIAS/74/193/1 , section III.)
